At least 2Gb of VRAM (low FPS) it's better if you have 4Gb.
Minimum 13Gb of RAM
Localization: English Crack: Included Description: VLCC-A Simulator — 2D + 3D Version This is the stable VLCC-A simulator package, including both the 2D and 3D terminals. The 2D terminal is fully functional and should work without any significant issues. The 3D terminal also works correctly, but you may encounter some network configuration issues when trying to connect it to the simulator manager (M terminal). If you have any problems establishing the network connection between the 3D terminal and the simulator manager, feel free to ask for help here in comments. I will do my best to help you troubleshoot it. I successfully patched the 3D and M terminals using dnSpy, so they should normally work correctly with the DMSCTS environment. IMPORTANT REQUIREMENT
You MUST have the DMSCTS Terminal.exe workstation software installed on your computer.
It can be downloaded for free from: ers3d.com
You may also find it on the forum by searching the simulator section for “DMSCTS”.
NOTICE / IMPORTANT INFORMATION
I did not modify the 3D and M terminals because the simulator was paid software.
The modifications were necessary because these terminals did not properly recognize the DMSCTS workstation environment.
The public simulators made available by the D.M.U. are free, and I would sincerely like to thank them for making these simulators accessible to everyone. Preserving access to this kind of simulation software is extremely valuable.
However, these simulators were originally hosted on Baidu Cloud, so I had to buy a UK virtual SIM for SMS verification and subscribe to Baidu's VIP service just to get acceptable download speeds lol.
Anyway, I wanted to share this with all the Seatrackers ^^, completely free of charge. (:
I've been looking for software like this since I was about 11 years old, so I know how frustrating it is to search everywhere and never find anything usable.
I hope this upload can save other people from going through the same struggle. ^^
INSTALLATION
Once you have downloaded the torrent, follow these instructions:
Do not extract the archive directly inside your Downloads folder.
Copy the downloaded archive into your DMSCTS simulator directory :
DRIVE:\Programs\DMSCTS\Simulators\
Extract the archive inside this folder.
Launch:
DMSCTS\Terminal.exe
ON THE LOGIN SCREEN:
If you already have an account, log in normally.
Otherwise, click the blue “Default Login” link.
Enter a room/session from the DMSCTS Terminal.
Open the extracted VLCC-A simulator folder.
Launch M and 3D with administrator privileges.
You can also launch 2D if you want to use 2D only or 2D and 3D together.
Wait for the simulator initialization to complete.
If the terminals fail to connect and you receive a message such as “Server Link Failed”, you can ask for help here.
Network configuration may sometimes be required depending on your computer and DMSCTS setup. Bye, and have fun with the simulator! ^^
Hello, @borice30 i tried the file, M does not seem to work properly, also downloaded latest terminal. M is like the bridge that synchronize 2d and 3d. what i am missing, M only show splashscreen but not loading, and sometimes indicates "The simulator is already running". help. thanks. do you succeed running both 2d and 3d? my main goal is to run 3d environment properly synch with 2d.
Hello ! it's ok, please follow the instructions below : 1/ check the M (DMSVLCCM.EXE) is not already running ---> do : ctrl+alt+supp and select "task manager" ----> search for any DMSVLCCM executable or Simulator executable. ----> if DMSVLCCM is running kill it using the "kill the task" or "stop" button. 2/Ensure to run M (DMSVLCCM) and 2D terminal with elevated privileges (run as administrator). it's very important ! let me know if it works. bye !
Hello! Thanks for the great sim. Im encountering a problem with the M. After starting up and pressing start it keeps throwing system.argumentoutofrangexpection right of the start. The chinese comment below translates to: "teacher he assistant system". The error prevents pumps from starting for example until you spam the error a couple times so it can execute some tasks or something? I understand what the expection means but have no idea where to start looking to fix it. You guys have any idea?
Thank you very much. Never expected it to be such a simple fix. That seemed to do the trick. Only thing that doesnt seem to work is in 3D the graphics settings. Is there a trick to it. It just seems to reset to the default "common quality"
Can anybody help me figure out the boilers. I want to start it in de 2d system but it keeps doing a flame out. In the start up procedure while doing ignition stage it doesnt open the fuel valves. Is that some kind of bug or am i missing something? Is there any manual as well or?
The VLCC-A DMSCTS 3D+2D+M (E.R.S Simulator)
Version: 2024
Developer: DMSCTS DALIAN MARITIME UNIVERSITY
64-bit OS compatibility: yes
System Requirements:
- At least 2Gb of VRAM (low FPS) it's better if you have 4Gb.
- Minimum 13Gb of RAM
Localization: EnglishCrack: Included
- You MUST have the DMSCTS Terminal.exe workstation software installed on your computer.
- It can be downloaded for free from: ers3d.com
- You may also find it on the forum by searching the simulator section for “DMSCTS”.
NOTICE / IMPORTANT INFORMATION- I did not modify the 3D and M terminals because the simulator was paid software.
- The modifications were necessary because these terminals did not properly recognize the DMSCTS workstation environment.
- The public simulators made available by the D.M.U. are free, and I would sincerely like to thank them for making these simulators accessible to everyone. Preserving access to this kind of simulation software is extremely valuable.
- However, these simulators were originally hosted on Baidu Cloud, so I had to buy a UK virtual SIM for SMS verification and subscribe to Baidu's VIP service just to get acceptable download speeds lol.
- Anyway, I wanted to share this with all the Seatrackers ^^, completely free of charge. (:
- I've been looking for software like this since I was about 11 years old, so I know how frustrating it is to search everywhere and never find anything usable.
- I hope this upload can save other people from going through the same struggle. ^^
INSTALLATION- Once you have downloaded the torrent, follow these instructions:
- Do not extract the archive directly inside your Downloads folder.
- Copy the downloaded archive into your DMSCTS simulator directory :
DRIVE:\Programs\DMSCTS\Simulators\ - Extract the archive inside this folder.
- Launch:
DMSCTS\Terminal.exe
ON THE LOGIN SCREEN:- If you already have an account, log in normally.
- Otherwise, click the blue “Default Login” link.
- Enter a room/session from the DMSCTS Terminal.
- Open the extracted VLCC-A simulator folder.
- Launch M and 3D with administrator privileges.
- You can also launch 2D if you want to use 2D only or 2D and 3D together.
- Wait for the simulator initialization to complete.
- If the terminals fail to connect and you receive a message such as “Server Link Failed”, you can ask for help here.
Network configuration may sometimes be required depending on your computer and DMSCTS setup.Bye, and have fun with the simulator! ^^
Y2023M11D07
Download [80 KB]
Share
Share
Minimum 13Go of RAM
13Go -> 13Gb
Share
Share
bye !
Share
Share
Share
Share
Share
