Технарь ®   19-Aug-2026 09:33
AutoCAD
Year: 2026
Version: 2027
Developer: Autodesk
Repacked by: m0nkrus
64-bit OS compatibility: yes
System Requirements:
  • 64-bit version of Microsoft Windows 10 (version 1809 or later), Windows 11
  • 2.5-2.9 GHz processor (3 GHz or higher recommended)
  • 8 GB of RAM (32 GB recommended)
  • 2 GB of video memory, 29 GB/s bandwidth, and DirectX 11 support (8 GB, 106 GB/s, and DirectX 12 recommended)
  • 1920x1080 screen resolution with True Color (up to 3840x2160 recommended for high-resolution and 4K displays)
  • 10 GB of available disk space (SSD recommended)
  • .NET Framework 4.8 or higher
Additional for 3D modeling and large data sets:
  • At least 32 GB of RAM
  • 6 GB of available disk space (excluding installation space)
  • Workstation-class graphics adapter with 12 GB of video memory or higher, a screen resolution of 3840x2160 (4K) or higher, True Color support, Pixel Shader 3.0 or higher, and DirectX support
Localization: English, Russian
Crack: Included (Read spoiler "How to install")
Description: AutoCAD is the world leader in 2D and 3D design solutions. With its increased visual impact, 3D modeling accelerates design work and documentation, enables model sharing, and the development of new ideas. Powered by machine learning technology, AutoCAD enables users to automate a wide range of design processes. Thousands of add-ons are available for AutoCAD, meeting the needs of a wide range of customers.
AutoCAD helps solve the most complex design problems. Freeform modeling tools enable the modeling of a wide variety of solids and surfaces; design review time is significantly reduced; parametric drawings help keep all necessary information at hand. Design ideas can be visualized in PDF format and even realized in 3D printed mockups. Never before have ideas become reality so quickly.
Repack info
What the author of the build has changed:
- The original Russian and English distributions have been merged into one.
- A solution for selecting the interface language of the program being installed has been developed and implemented for the modern installer.
- The installer's interface language is set based on the OS interface language.
- Since AutoCAD 2026 lacked the so-called "classic interface" by default, I thought it would be possible to restore it for those who need it.
- The installation package now includes the option to install local help for both the English and Russian versions of the program.
- The installation package now includes the option to install the AutoCAD 2027 VBA Enabler module.
- The installation package now includes the option to opt out of installing AutoCAD Activity Insights and ADP Insight Client modules.
- The installation package now includes the option to opt out of installing AutoCAD BlockIndexer 2027.
- The installation package now includes the option to opt out of installing AutoCAD Open in Desktop.
- Added the option to opt out of installing the Autodesk Featured Apps module to the installation package.
- Added the option to opt out of installing the Autodesk Save to Web and Mobile module to the installation package.
- Added the option to opt out of installing the Autodesk CER Service module to the installation package.
- Added the option to opt out of installing the Autodesk App Manager module to the installation package.
- Removed the Autodesk Access module from the installation process. Manual installation remains available.
- Autodesk Access Service Host will be disabled in the product installed from the build.
- Removed the Autodesk Identity Manager module from the installation package.
- Removed the Autodesk Genuine Service module from the installation package.
- Disabled the automatic update mechanism for the Autodesk Licensing module.
- Added AutoCAD 2027 Update to the installation package.
- Partially added AutoCAD Architecture 2027 Update to the installation package.
- The Autodesk On-Demand Install Service utility has been updated to version 2.17.0.102.
- Everything needed to repair the program is located inside the image in the Crack folder.
How to install
0. Disable antivirus and mount iso file
1. Install Autodesk AutoCAD 2027 (Setup.exe file).
2. Run AdskNLM.exe from the Crack folder and wait for the message "Cracking complete. Enjoy!" to appear.
3. Launch the installed application. In the license type selection window, click "Use a network license."
4. Download and extract Autocad_2027_Addons.zip (download each torrent end install)
5. Enjoy your registered version of the product!
Addons
Attachments Autocad_2027_Addons.zip (231 KB, Downloaded: 10 times)
Addons: Civil 3D 2027, MEP 2027, Mechanical 2027, Advance Steel 2027, Electrical 2027, Architecture 2027, Map 3D 2027, Plant 3D 2027
Download [18 KB]
Технарь ®   19-Aug-2026 10:06
Бонус: dwg чертежи судовых поршней, втулок, общие планы, редукторы, турбоприводы, валопроводы и прочее. 400+ чертежей
Link для VIP пользователей:
Hidden text: ** You do not have enough reputation to view the hidden text (required 200) **
Примеры чертежей
eSail Sailing Simulator v.1.5.31 - eSail [2023]
Seafarer: The Ship Sim 1.0.0.2651_7 + DLC Voyager Edition (RePack by FitGirl) - Astragon [2026]
HMC ECDIS v.5.1 [2014]
Chart Planner v.3 [2016]
DELFTship Free v.18.10 (360) - DELFTship Maritime Sofware [2026]
Virtual Sailor NG v.9.9.8 (Build 12579718) - Ilan Papini [2023]
TimeZero Navigator v.4.2.0.133 - Nobeltec & MaxSea [2022]
The time now is: Today 00:48
