tomado ®   26-Aug-2022 17:27
TimeZero Navigator V 4.2.0.133
Year: 2022
Version: 4.2.0.133
Developer: Nobeltec & MaxSea
Localization: English
Crack: Included
System Requirements:
  • Microsoft® Windows® 7 SP1 / 8.1 / 10
  • 1.5 GHz processor (Intel i5 recommended)
  • 4 GB RAM
  • Video card:
    • Minimum — Integrated Intel Graphic Chipset (HD Series)
    • Recommended — Dedicated Graphics with 1 GB VRAM or Intel HD 4th Generation or above
  • Screen resolution: 1024×600 (1280×800 or higher recommended)
  • Hard Drive: 30 GB free space
  • USB or Serial port for NMEA183
  • Actisense USB NGT-1 for NMEA2000
  • 100 Base-T Network Card for Ethernet devices (e.g. Furuno FA30)
Description:
The functionalities of the TZ Navigator navigation software have been developed with two major objectives: total control and user comfort, with optimization focused on safety and simplicity.
TimeZero technology provides global coverage with smooth and fast mapping, where cartography, 3D data and aerial photos are seamlessly merged.
The user interface is intuitive and optimized for touch screens.
Via a simple Ethernet connection, it is compatible with Furuno NavNet systems. This allows:
  • Radar image overlay directly on the map (optional TZ Radar module)
  • Use of Furuno sonar features on PC:
    • Real-time ultrasound
    • Fish detection
    • Bottom discrimination (optional TZ Sonar module)
For motorboats, advanced route management, safety cone and AIS functions ensure stress-free sea trips.
For sailing, TimeZero offers tools such as:
  • Waypoints (WP)
  • Routes
  • Tides
  • Weather forecasts
  • AIS / ARPA
With the optional weather routing module, you can calculate the optimal route based on forecast data and boat polars.
Additional Info
On Windows Defender, allow:
  • The Keygen MaxLicV4Nav
  • MX_TZ v4PRO_crack_SplahScreen
before downloading.
Installation Instructions
  • Turn off the internet connection.
  • Run the installer "InstallNavigator4.2.0.133".
    After installation, uncheck "Do you want to Run TimeZero" and close the popup window.
  • Run "MX_TZ v4PRO_crack_SplahScreen.bat" and press Continue. It will close automatically.
  • Run "Block Host.cmd" to prevent UM code issues.
  • Run the keygen "MaxLicV4Nav.exe" and the TZ4 application.
  • Generate a serial number and enter it into TZ.
  • Copy the SC code into the keygen and generate the AC code.
Congratulations! Installation completed.
Enjoy!
Note: The keygen allows you to generate the chart serial key.
Thanks to all contributors from
https://www.gpspower.net/
[url=http://seatracker.me/i/p/95/8b/958b34a8af5f8e289fb2661de22a3613.png]
[img]http://seatracker.me/i/t/95/8b
Download [19 KB]
tomado ®   27-Aug-2022 12:51
ngiann, good day,
Available modules with the provided keygen
you will find this UM Code : C8521D9DB6196B5F0053
click me
4
no1r   29-Aug-2022 14:36
Thank you. This is just perfect.
Maybe someone know about VTS areas information (calling channel, name of the area), is it available somewhere or should it be done only by user layer feature(something like in attached pic below)?
click me
3
tomado ®   29-Aug-2022 15:40
no1r, Good day,
If you need more informations , you have to double click on the TSS arrow
But it better to always refer to Sailing Directions.
click me
I hope that I've answered your question
3
Guest   30-Aug-2022 08:58
how to update the weather info in v4 ? in v3 there was an update by email. In version 4 does not work...
skalarx   30-Aug-2022 09:03
ngiann   01-Sep-2022 18:11
Do I must have Internet connection off in all installation steps?
When is safe to turn it on again?
Kwifi   01-Sep-2022 18:16
Thanks a lot ! Can't wait to try !
Edit: Followed to guide and not connected to internet but it exits everytime I type activation code. It just says "Exiting".
tomado ®   01-Sep-2022 20:12
ngiann, Good day,
You can run your internet connection when you complete installation
tomado ®   01-Sep-2022 20:15
Kwifi, Good day,
Go to C:\ProgramData\CrypKey\Licenses and delete the folder containing the serial key.
Try again with another SC AND AC licence generated with the keygen.
TimeZero Professional v.4.2.0.132 - Nobeltec & MaxSea [2022]
HMC ECDIS v.5.1 [2014]
Rose Point ECS v.4 - Rose Point [2020]
EIVA Kuda Core v.4.8.0 - EIVA [2025]
Transas ECDIS Demo 2.0 v.2.00.015 - Transas [2010]
One Ocean v.10.2.8 - ChartCo [2022]
DELFTship Free v.18.10 (360) - DELFTship Maritime Sofware [2026]
ChartBrowser v.2.4.6.8 - ChartWorld [2018]
The time now is: Today 21:27
