twicer ®   11-Feb-2026 11:23
2026 EZ Celestial Nautical Almanac
Year: 2025
Author: EZ Celestial LLC
Genre: Handbook
Publisher: EZ Celestial LLC
Edition: July 2025
ISBN: 978292957799
Pages count: 293
Description: Complete 2026 Nautical Almanac including all daily pages for one year, the Pole Star Tables, and all interpolation and correction tables available in the official Nautical Almanac. Everything you need to find the GHA and Declination of the observed body and correct your sextant altitude observation (Hs) and produce the observed altitude (Ho) need for the sight reduction.
Note that it does NOT include other sections of the official Nautical Almanac not mentioned above (detailed explanations, concise sight reduction tables, etc.). This book is compiled from pages that are generated and can be output/printed from the ezAlmanacOne app.
If you don't have the app or just want a pre-printed Nautical Almanac as a backup on a passage, this book is an economical version of the same data you will find in the USNO, HMNAO, or commercial version of the Nautical Almanac.
Additional info: include: NA Lunar Supplement Lunars are easy when you have the pre-computed lunar distances!
This book has an entire year of pre-computed lunar distances - up to six of the best objects to use each day with distances at 3-hour intervals. It includes all other tables necessary to do lunars just like the ancient navigators of the 1800's. Forms and full instructions for using the tables are included. Easily clear the lunar distance and compute Greenwich time with pencil, paper and NO calculator.
na
Download [26 KB]
2022-2023 EZ Celestial Nautical Almanacs - EZ Celestial LLC [2022, PDF]
2025 EZ Celestial Nautical Almanac - EZ Celestial LLC [2024, PDF]
2022-2023 NA Lunar Supplements and Mathmatics of Longitude - EZ Celestial LLC [2022, PDF]
2025 EZ Celestial Nautical Almanac Lunar Supplement - EZ Celestial LLC [2024, PDF]
NP-314-25 The Nautical Almanac - UKHO [2024, PDF]
Nautical Almanac 2017 + Excel программы для расчета [2016-2017, PDF]
Astro Calculator v.1.0.0 - DBG Nautical [2020] [Android]
100 Problems in Celestial Navigation - Gray L. [2010, PDF]
Celestial Navigation, A Practical Guide to Knowing Where You Are - Dave Berson [2018, EPUB]
The time now is: Today 16:46
