paolina_3 ®   20-Jun-2020 16:38
Celestial Navigation, A Practical Guide to Knowing Where You Are
Year: 2018
Author: Dave Berson
Publisher: Seahorse Publishing
ISBN: 9781944824037
Format: EPUB
Pages count: n/a
Description: The aim of this book is to present, in a simple and direct way, the basics of celestial navigation, and also to correct many misconceptions surrounding its learning and practice. It is no longer true, for example, that mariners should be familiar with spherical trigonometry. Nowadays sight reduction tables in use (HO 249) have been simplified, and a mathematical knoweledge is no longer necessary; they are specifically designed for a simple and fast use. Another misconception is that celestial navigation is outmoded and has no value. Of course GPS and its accuracy must be in everyday's use, but GPS relies on satellites and is neither easy nor inexpensive to troubleshoot. Celestial navigation, on the other hand, is virtually foolproof, once the basics are mastered, and so important that the US Navy has reinstated teaching it to its cadets at the Naval Academy.
The author, a columnist for Ocean Navigator magazine and a sailing instructor, describes, in a concise and clear way, the basics of the celestial navigation; the celestial sphere, the nautical almanac, time and local hour angle, dead reckoning and assumed position, the sextant, sight reduction and use of HO 249 tables, the noon sight.
Celestial Navigation, A Practical Guide to Knowing Where You Are.epub
Download [6 KB]
100 Problems in Celestial Navigation - Gray L. [2010, PDF]
GPS Backup with a Mark 3 Sextant: All Instructions and Tables Included - David Burch [2021,…
Celestial Navigation - Tom Cunliffe [2010, PDF]
2026 EZ Celestial Nautical Almanac - EZ Celestial LLC [2025, PDF]
Sight Reduction Tables for Marine Navigation. Vol.3 - USA Defence Mapping Agency Hydrographic…
Sight Reduction Tables for Marine Navigation. Vol.4 - USA Defence Mapping Agency Hydrographic…
US Navy Course - Quartermaster Navedtra 14338 - Collective [2013, PDF]
The Projection and Calculation of the Sphere - S. M. Saxby [1861, PDF]
Primer of Celestial Navigation - John Favill [1944, PDF]
Sight Reduction Tables for Marine Navigation - National Imagery and Mapping Agency USA [2015, PDF]
The time now is: Today 16:46
