Romate ®   19-Nov-2025 11:47
2021 IBC Code Implementation Tool
Year: 2020
Author: Intertanko
Publisher: Intertanko
Edition: 1st edition
Pages count: 29
Description: A comprehensive set of amendments to the International Code for the Construction and Equipment of Ships carrying Dangerous Chemicals in Bulk (IBC Code) effective 1 January 2021 (Res. MEPC. 318(74)) may impact the carrying capacity and carriage requirements of all chemical tankers (i.e. new and existing).
The primary changes to the IBC Code include:
• Revision of carriage requirements of chemical products found in Chapter 17.
See Appendix 1 for IBC Code Chapter 17 old versus new comparison. The 806 products listed in Chapter 17 have the old requirements side-by-side with the 2021 requirements, with the red boxes indicating that there has been a change with the new (2021 IBC Code) carriage requirements.
• Revised Chapter 18, see Appendix 2
• Products no longer listed in Chapter 17, see Appendix 3
• Appendix 4 captures some of the most relevant changes to the IBC Code and contains lists of products representing the most significant changes.
New demanding operational requirements in MARPOL Annex II (Res. MEPC.315(74)), Regulation 13.7.1.4 are also effective 1 January 2021, imposing to tankers operating in specific areas (i.e. Northwestern European waters, Baltic Sea area, Western European waters, Norwegian Sea) a prewash procedure for certain persistent floating products identified by reference to paragraph 16.2.7 in column “o” of IBC Chapter 17.
Additional info: These new requirements apply to persistent floating products with a high viscosity and/or high melting point; and include, for example: Fish oil, Olive oil, Palm oil, Paraffin wax highly refined, and Sunflower seed oil.
The complete list of products to which it applies and the detailed description and geographical coordinates of the areas of application of the new requirements are attached as Appendix 5 and Appendix 6 respectively.
Intertanko-2021-ibc-code-implementation-tool.pdf
International Code for the Construction and Equipment of Ships Carrying Dangerous Chemicals in Bulk…
The Revisions to MARPOL Annex II A Practical Guide - INTERTANKO [2007, PDF]
IBC Code 2007 - IMO [2007, PDF]
A Guide for Correct Entries in the Oil Record Book (Part I & II) - Intertanko [2014, PDF]
INTERTANKORB ORB PART I - INTERTANKO [2014, EPUB]
INTERTANKORB ORB PART II - INTERTANKO [2014, EPUB]
A Guide for correct entries in the Oil Record Book (Part I - Machinery space operations) -…
POLAR Code (The International Code for Ships Operating in Polar Waters) - KS Gill [2016, PDF]
The time now is: Today 14:15
