vitbar192 ®   04-Oct-2024 19:02
Reduction Of A Ships Magnetic Field Signatures
Year: 2008
Author: Holmes J.J.
Genre: Textbook / Research book
Publisher: Springer Cham
ISBN: 9781598292480, 9781598292497
Pages count: 78
Description: Decreasing the magnetic field signature of a naval vessel will reduce its susceptibility to detonating naval influence mines and the probability of a submarine being detected by underwater barriers and maritime patrol aircraft. Both passive and active techniques for reducing the magnetic signatures produced by a vessel's ferromagnetism, roll-induced eddy currents, corrosion-related sources, and stray fields are presented. Mathematical models of simple hull shapes are used to predict the levels of signature reduction that might be achieved through the use of alternate construction materials. Also, the process of demagnetizing a steel-hulled ship is presented, along with the operation of shaft-grounding systems, paints, and alternate configurations for power distribution cables. In addition, active signature reduction technologies are described, such as degaussing and deamping, which attempt to cancel the fields surrounding a surface ship or submarine rather than eliminate its source. Table of Contents: Introduction / Passive Magnetic Silencing Techniques / Active Signature Compensation / Summary
Additional info: Dr. John J. Holmes received his B.S. (1973), M.S. (1974), and Ph.D. (1977) degrees in electrical engineering from West Virginia University. He joined the Naval Surface Warfare Center (1977) and is currently the Senior Scientist for the Underwater Electromagnetic Signatures and Technology Division, where he is responsible for the development of underwater electromagnetic field signature reduction systems for surface ships and submarines. Dr. Holmes has written 24 peer-reviewed papers, holds 10 patents, received the David Packard Excellence in Acquisition Award (1999), the Meritorious Civilian Service Award (1986), and is a senior member of the Institute of Electrical and Electronic Engineers.
Holmes J.J. Reduction Of A Ships Magnetic Field Signatures, 2008.pdf
Download [6 KB]
Reduction of a Ship’s Magnetic Field Signatures - Holmes J.J. [2008, PDF]
2023 International Conference on Marine Equipment & Technology and Sustainable Development - Desen…
Controller Design, Analysis & Prototype for Ship Service Converter Module - Benjamin D. Salerno…
VFD Challenges for Shipboard Electrical Power System Design - Mohammed M. Islam [2019, PDF]
Geometry For Naval Architects - Adrian Biran [2019, PDF]
Sonar for Practising Engineers, 3rd Edition - A. D. Waite [2002, PDF]
Design of Propulsion and Electric Power Generation Systems - Woud H.K, Stapersma D. [2003, PDF]
Naval Warfare Handbook - Kemp I. [2022, PDF]
Handbook of Air Conditioning and Refrigeration - Shan K. Wang [2000, PDF]
The Impact of Design to Cost on Naval Ship Design - Michael Nickelsburg [1975, PDF]
The time now is: Today 18:59
