vitbar192 ®   22-Nov-2020 10:13
Reduction of a Ship’s Magnetic Field Signatures
Year: 2008
Author: Holmes J.J.
Genre: Technical book
Publisher: Morgan and Claypool Publishers
ISBN: 159829248X
Pages count: 78
Description: Decreasing the magnetic field signature of a naval vessel will reduce its susceptibility to detonating naval influence mines and the probability of a submarine being detected by underwater barriers and maritime patrol aircraft. Both passive and active techniques for reducing the magnetic signatures produced by a vessel's ferromagnetism, roll-induced eddy currents, corrosion-related sources, and stray fields are presented. Mathematical models of simple hull shapes are used to predict the levels of signature reduction that might be achieved through the use of alternate construction materials. Also, the process of demagnetizing a steel-hulled ship is presented, along with the operation of shaft-grounding systems, paints, and alternate configurations for power distribution cables. In addition, active signature reduction technologies are described, such as degaussing and deamping, which attempt to cancel the fields surrounding a surface ship or submarine rather than eliminate its source.
Holmes J.J. Reduction of a Ship’s Magnetic Field Signatures, 2008.pdf
Reduction Of A Ships Magnetic Field Signatures - Holmes J.J. [2008, PDF]
Warships Today: Over 200 of the World’s Deadliest Fighting Ships - Chant C. [2004, PDF]
Fin Stabilizers as Maneuver Control Surfaces - Martin G. Sarch [2003, PDF]
Study and analysis of the use of wind power for the propulsion of merchant vessels. Case study. - Da...
Human factors for naval marine vehicle design and operation - JONATHAN M. ROSS [2009, PDF]
Mathematical Modeling of inland vessel Maneuverability considering rudder hydrodynamics - Jialun Liu...
Requirements for Liquified Hydrogen Carriers - ABS [2023, PDF]
Mitigating Shipping Emissions in European Ports, Social and Environmental Benefits - Alexandra Marag...
Corrosion Inspection and Monitoring - Pierre R. Roberge [2007, PDF]
Stabilization, Tracking and Formation Control of Autonomous Marine Vessels - Ge Guo, Zhenyu Gao, Pen...
The time now is: Today 14:02
