vitbar192 ®   14-Apr-2024 08:22
The Boat Maintenance Bible
Year: 2011
Author: Compton N., Doughty S.
Publisher: Bloomsbury Publishing Plc
Format: PDF/EPUB
Pages count: 675
Description: t is said that owning a boat is like standing under a shower and tearing up money. Well, no more. This book shows you how to perform all those essential jobs on your boat –
whether it be a sailboat, powerboat or dinghy – without having to call in expensive expert help. From cleaning off rust stains to servicing your engine and refurbishing the
woodwork, it’s all explained in clearly illustrated, easy-tofollow stages.
A hull with an osmosis problem. Use a small mechanical grinder to remove osmosis blisters from the hull and then repair by filling with gel coat.
Compton N., Doughty S. The Boat Maintenance Bible, 2011
Download [58 KB]
The Boat Improvement Bible - Chamberlain-Webber J. [2015, EPUB]
Inspecting the Aging Sailboat - Casey D. [1997, PDF/EPUB]
The Sailing Bible - The Complete Guide to Dinghy Sailing - Holmes R., Evans J. [2014, PDF]
The Yacht Owner’s Manual - Everything you need to know to get the most out of your yacht - Du Port A...
The Yacht Owner’s Manual: Everything you need to know to get the most out of your yacht - Andy Du Po...
Don Casey’s Complete Illustrated Sailboat Maintenance Manual: Including Inspecting the Aging Sailboa...
The Dinghy Bible - Rupert Holmes, Jeremy Evans [2014, EPUB]
Sailing Big On A Small Sailboat - Jerry D. Cardwell [1997, PDF]
Maintenance and Repair for Diesel Engines - Jean Luc Pallas [2013, PDF]
Simple Boat Maintenance - Manley P. [2014, PDF]
The time now is: Today 23:02
