CaptainWhite ®   13-Nov-2017 00:33
Don Casey's Complete Illustrated Sailboat Maintenance Manual: Including Inspecting the Aging Sailboat
Year: 2005
Author: Don Casey
Publisher: International Marine/Ragged Mountain Press
Edition: 1 edition (Oct. 6 2005)
ISBN: 978-0071462846
Format: EPUB
Pages count: 896
Description: The definitive guide from the world's best-known sailboat maintenance expert
Don Casey’s Complete Illustrated Sailboat Maintenance Manual combines six core volumes into a single, utterly dependable resource that answers every frequent question, explains every major system, and helps you keep your boat and its components shipshape.
More than 2,500 clear and detailed illustrations guide you step by step through every procedure. Casey’s technical virtuosity, his user-friendly explanations, and Peter Compton's diesel engine expertise make even the more complicated repairs and improvements easy to understand.
This must-have guide saves you time, money, and grief as you learn the fastest, easiest, most effective ways to:
- Evaluate the condition of your boat or one you’re about to purchase
- Repair structural damage to your fiberglass sailboat
- Improve or repair your sailboat’s electrical system
- Troubleshoot, maintain, and repair your boat’s diesel engine
- Put a professional-looking finish on your boat’s hull, deck, spars, wood, and trim
- Make and repair sails, sail covers, dodgers, awnings, sailbags, and bimini tops
DonCasey
Inspecting the Aging Sailboat - Casey D. [1997, PDF/EPUB]
Spurr’s Guide to Upgrading Your Cruising Sailboat - Spurr D. [2006, PDF/EPUB]
Diesel Engine Care and Repair - Calder N. [2007, PDF]
The Liveaboard Report: A Boat Dweller’s Guide to What Works and What Doesn’t - Charlie Wing [1993, P...
Understanding boat design - Ted Brewer [1993, PDF]
The Complete Guide to Trailering Your Boat - Smith B. [2008, PDF]
Get Your Captain’s License - Charlie Wing [2015, EPUB/PDF/MOBI]
The International Marine light list & waypoint guide - from Alaska to Panama, including Hawaii, - Ke...
Sailors Book of Small Cruising Sailboats - Henkel S. [2010, PDF]
100 Fast & Easy Boat Improvements - Don Casey [1998, EPUB]
The time now is: Today 11:03
