Gogo81 ®   03-Mar-2024 00:11
The Fiberglass Boat Repair Manual
Year: 1988
Author: Allan Vaitses
Publisher: International Marine/Ragged Mountain Press
Edition: First
ISBN: ‎ 978-0071569149
Pages count: 177
Description: "This book will save you money and grief before you can say woven roving."--Sailing
"A comprehensive and accurate work that should benefit almost any owner of a fiberglass boat."--SAIL
"This book will prove a valuable addition to the library of any boat builder or owner who is seriously interested in doing his own repairs, as well as intercepting minor problems before they become major projects."--Boatbuilder
Are there hairline cracks in your boat's deck or topsides gelcoat? Have her color and luster faded over the years? Does she have deck leaks? Has she been holed? Is her hull oilcanning in a sea? If your answer to any of these questions is yes, this book is for you. This is the definitive guide for fiberglass boat repair and beautification, covering not just cosmetic dings and scratches, but also major repairs of structural damage to hull and decks. It will show you how to:
replace deteriorated gelcoat, or repair the flaws in an existing gelcoat and recoat it with polyurethane or marine alkyd enamel paint;
strengthen a weak and overly flexible hull or deck;
tab in loose hull liners and joinerwork;
make templates from the good side of a hull to reshape large shattered or missing areas on the other side;
repair or replace water-saturated deck cores;
repair keels, rudders, and centerboards;
rebed and refasten underwater and on-deck hardware;
rebed, refasten, and strengthen hull-to-deck joints;
fix broken hatches, and make new ones when necessary;
treat the symptoms and causes of overstressed hulls.
That beautiful craft swinging at anchor or nestled dockside, her topsides reflecting water and sky like a polished mirror, could be yours. Here's how.
Don Casey’s Complete Illustrated Sailboat Maintenance Manual: Including Inspecting the Aging Sailboa...
Outboard Engines - Maintenance, Troubleshooting, and Repair - Sherman E. [2009, PDF]
Powerboater’s Guide to Electrical Systems - Edwin Sherman [2007, PDF]
Boatowner’s Guide to Modern Maintenance - John Duffett [1985, PDF]
Covering Wooden Boats With Fiberglass - Allan H. Vaitses [1989, EPUB]
Marine Diesel Engines | Care and Maintenance - Peter Caplen [2011, EPUB/PDF/MOBI]
Spurr’s Guide to Upgrading Your Cruising Sailboat - Spurr D. [2006, PDF/EPUB]
Aero-Hydrodynamics and the Performance of Sailing Yachts - Fossati F. [2010, PDF/DjVu]
Fiberglass Boat Repairs Illustrated - Roger Marshall [2009, PDF]
Fibreglass Boats: Construction, Gel Coat, Stressing, Blistering, Repair, Maintenance - HUGO DU PLESS...
The time now is: Today 15:16
