MaritimeNews ®   07-Jul-2015 06:26
Clean Air Engineering-Maritime (CAEM) has received California Air Resources Board (CARB) approval for the first commercially ready ship emissions capturing system called the Maritime Emissions Treatment System (METS).
The METS-1 is CAEM’s first-generation system. It is mounted and deployed from a barge that is positioned alongside ships berthed at the Port of Los Angeles.
The system is positioned over vessels’ smoke stacks and captures and treats more than 90 percent of particulate (PM), NOx, SO2, and related diesel pollutants emitted, CAEM says.
“In recent years, we have supported development of this technology through our Technology Advancement Program,” said Port of Los Angeles Executive Director Gene Seroka.
“With CARB verification approval, this is now a solution that other ports can consider to lower vessel emissions in their harbors and surrounding communities.”
https://www.youtube.com/watch?v=ppJwRYALdbI
METS is the first CARB-approved alternative to “plugging in” to shore-side power — also called cold-ironing or Alternative Maritime Power — which is the current standard for meeting California’s “Airborne Toxic Control Measure for Auxiliary Diesel Engines Operated on Ocean-Going Vessels At-Berth in a California Port” (At-Berth) regulation.
Since January 1, 2014, vessel operators not complying with the regulation run the risk of not meeting these emissions standards and being hit with significant fines.
“The METS-1 will have an immediate, direct and positive impact on the communities surrounding the Port of Los Angeles and Long Beach,” said Nick Tonsich, CAEM principal.
“In the long term, given the fact that there are so many ships in the world’s fleet without cold-ironing capability, the METS system could have a profound impact on the entire shipping industry and our global environment.”
More than a decade ago, the Port of Los Angeles pioneered development of Alternative Maritime Power (AMP) for cargo ships. Today, 24 berths at the Port of Los Angeles are equipped for shore power, the most of any port in the world.
AMPing at berth eliminates upwards of a ton of NOx emissions per vessel per 24-hour period. Similar results have been demonstrated by the new METS alternative, says CAEM.
The CARB testing, which began last year, included performance evaluations of the METS on five separate vessels for a minimum of 200 hours.
Partial funding for the METS project came from a USD 1.5 million grant from the Port of Los Angeles’ Technology Advancement Program (TAP) to TraPac, LLC, a container terminal located in the Port of Los Angeles.
TraPac contracted with CAEM to conduct research and develop the METS project. TraPac has entered into a service agreement for use of the METS-1 at TraPac on all vessels that are not AMP capable. Provisions in the TAP grant make it possible for the Port of Los Angeles to receive repayment of the grant proceeds.
CAEM, which is based in San Pedro, California, has committed to donating all profits from the METS-1 system to local charities that serve the port communities.
Black carbon emissions and fuel use in global shipping, 2015 - Bryan Comer, et al. [2017, PDF]
Guide to South Korea’s Vessel Speed Reduction (VSR) programme - Intertanko [2020, PDF]
On Shore Power Supply and LNG - TrainMoS II [2015, PDF]
Diesel-Engine Management - Robert Bosch GmbH [2006, PDF]
California Air Resources Board (CARB) 2020: At Berth Regulation - CARB [2020, PDF]
Sustainability whitepaper: Biofuels as marine fuel - ABS [2021, PDF]
Guidelines for Shipboard CO2 Capture and Storage Systems - ClassNK [2023, PDF]
Natural Gas Engines - For Transportation and Power Generation - Kalyan Kumar Srinivasan [2018, PDF]
BW LPG Operations Manual - BW LPG Ltd. [2016, PDF]
Model Ballast Water Management Plan - Lloyd’s Register [2020, docx]
The time now is: Today 20:48
