khany ®   08-Jan-2024 13:23
Steel Coil Loading Software Cargo hold evaluation tool (EXCEL)
Year: 2023
Version: 1.4
Developer: BV
System Requirements: Microsoft Excel
Localization: English
Crack: Not needed
Description: Steel Coil allows Bureau Veritas to evaluate plating and ordinary stiffeners subject to steel coil loadings not covered by the loading manual of in-service CSR rules. Our software provides an assessment of the Rules criteria for local strength of a cargo hold for a foreseen steel coil loading arrangement, based on the detailed inputs of holds structure scantlings and geometry.
  • Version 0.96 corresponds to the Common Structural Rules for Bulk Carriers - July 2012, for vessels built prior to July 1, 2015 - release date 21th September 2023
  • Version 1.4 corresponds to the Common Structural Rules for Bulk Carriers and Oil Tankers - 1st January 2015, for vessels built after July 1, 2015 - release date 21th September 2023
SteelCoil
Download [174 B]
ComposeIT v.4.1.1 - BV [2023]
BV - Rules for the Classification of Steel Ships - PART B – Hull and Stability -2021 - BUREAU…
PrimeShip SteelCoilLoading Program v.3.23 - ClassNK [20??]
Rules of Bureau Veritas (BV) - [2018, PDF]
BV - Rules for the Classification of Steel Ships - PART D – Service Notations - 2021 - BUREAU…
The Principles of Naval Architecture Series--Strength of Ships and Ocean Structures - Prof. Alaa…
Guide for Slamming Loads and Strength Assessment for Vessels - ABS [2021, PDF]
Common Structural Rules for Bulk Carriers and Oil Tankers - IACS [2019, PDF]
The time now is: Today 14:20
