namemamun ®   25-Dec-2023 17:07
Encyclopedia of lubricants and lubrication
Year: 2014
Author: Theo Mang
Genre: Encyclopedia
Publisher: Springer
Pages count: 2413
Description: Lubrication is certainly an essential, if not the essential, area of tribology.
Virtually all moving parts are lubricated and suitable lubricants are employed
to maximize the lifetime of machine elements and to minimize energy
consumption and overall costs. Making lubrication successful requires combined
efforts: selecting the right lubricant, using the right lubricating system,
keeping the lubricant in good conditions, incorporating properly the lubricant
into the engineering process as a machine element, finding the suitable test
procedure to check the efficiency of the lubricant, selecting the right criteria
to protect the environment and to improve the energy efficiency and, last but
not least, finding the overall economically best solution.
The Encyclopedia of Lubricants and Lubrication will be a leading and
comprehensive reference work covering all major aspects of the science,
technology and application of lubricants and lubrication, friction, wear and
related fields.
It took more than 3 years of hard work of outstanding experts in awide range
of disciplines to compile this encyclopedia.
Encyclopedia of lubricants and lubrication.pdf
Download [19 KB]
Lubrication and Lubricant Selection - A R Lansdown [2004, PDF]
Design and Selection of Check Valves - Val‐Matic [2018, PDF]
Shipping Operations Management - I.D. Visvikis, P.M. Panayides [2017, PDF]
Understand Marine Lube Oil Analysis Report - None [2015, PDF]
Biodiesel Soot: Tribology, Properties, and Formation - XIANGUO HU CHUAN LI [2021, PDF]
Encyclopedia of ocean sciences - Steele J.H. at all [2001, PDF]
Water-Lubricated Journal Bearings | Marine Applications, Design, and Operational Problems and…
Design Rules for Actuators in Active Mechanical Systems - Gomis-Bellmunt O., Campanile F. [2009,…
Theory of Lubrication - Mihir Kumar Ghosh , Bankim Chandra Majumdar , and Hihir Sangri [2013, PDF]
Springer Handbook of Ocean Engineering - Dhanak M.R., Xiros N.I. [2016, PDF]
The time now is: Today 15:09
