namemamun ®   23-Dec-2023 11:29
Operators guide to rotating equipment
Year: 2014
Author: Julien LeBleu, Jr. and Robert Perez
Genre: Handbook
Pages count: 106
Description: Rotating machines power our production facilities by safely transporting a wide variety of liquids,
gases, and solids. Those of you who have worked in a production site for any length of time know that
not all process machines are created equal. Some are more critical than others; some are small and
some are very large; some spin fast and some turn very slowly. The great diversity in their
construction and application can be daunting to a new operator and a challenge to the veteran.
When process machines fail catastrophically, bad things happen. These bad things are called
consequences; but not all consequences are equal. For example, if a critical machine fails, the
consequence can be the stoppage of an entire process or even an entire process facility, which may
have a significant cost related to the outage if it is lengthy. Another consequence associated with
machinery failure is the release of a dangerous process fluid if its seal fails. A final example is the
cost of a major machine failure. If an internal mechanical failure is not detected early, more and more
secondary damage will be incurred, eventually resulting in a hefty repair bill. Catastrophic failure
can cause serious safety and environmental issues as well.
Operators guide to rotating equipment.pdf
Download [4 KB]
Operator’s Guide to Rotating Equipment - Julien LeBleu Jr., Robert Perez [2014, PDF]
Ventilation and Energy Efficiency in Welding Shops - lexander Zhivov [2022, PDF]
Electrical Submersible Pumps Manual - Gabor Takacs, Ph.D [2018, PDF]
Pump Wisdom: Essential Centrifugal Pump Knowledge for Operators and Specialists - Robert X. Perez , ...
Electrical Overview on Main & Auxiliary Generating Sets [2021, MP4]
Barge Stability Guidelines - Maritime New Zealand [2006, PDF]
Power Boating for Dummies - Vance R. [2009, PDF]
Boiler Control Systems Engineering - G. F. (Jerry) Gilman [2010, PDF]
F(P)SO Heading Control Guidelines - OCIMF [2020, PDF]
Guidelines for Ships Using Alternative Fuels - ClassNK [2024, PDF]
The time now is: Today 19:39
