skipper3362 ®   01-May-2023 18:09
Meterology 401: Hurricane Tracking Workshop
Year: 2022
Playtime: 51m
Quality: WEB-DL
Format: MP4
Video: H.264 1280x720 30 fps
Audio: AAC 48.0 KHz x 320 Kbps
Description: How to Read Hurricane Models, Charts, and Maps
What you'll learn
how the computer models read the hurricance using data from airplanes
how to track a tropical system using public weather tools and models
learning to read surface weather maps and conditions needed for hurricanes
when to consult other advanced weather tracking tools for help in the future
Requirements
None
Description
This course is designed to give you an introduction to the basics of reading and tracking a hurricane on a map. It will include learning about some of the well known supercomputer models like the GFS, EURO, and the consensus blend of models 9 which is an best avg of 30 models combined basically)that you would hear about on your local weather broadcast. We will first define the prime conditions needed for a hurricane and show you how to read the signs and symbols used on maps and data provided by the National Hurricane Center. Other models are discussed in passing and this is not intended to show you the best model but give you a broad overview of what the look for when reading hurricane analysis 3-5 days out in the infamous "cone of uncertainty". As always hazards with hurricanes can occur outside of the cone and also it should be noted that the cone shows the center track of the storm and that landfall location is not as important as impacts. However, knowing where to look for signs and how to read them at a base level is important. We will also discuss briefly water vapor images, steering currents such as the persistent Bermuda High or dips in the jet stream towards the south of the US that happen around this time of year in America etc... You should enjoy this course and use the websites in your everyday discussion and hurricane planning. It is not an exact science but its getting so much better than in the 1960's when RADAR and recon planes where just starting to get going with the weather.
Overview
Section 1: Introduction
Lecture 1 Introduction
Section 2: Hurricane Tracking Essentials Part 1
Lecture 2 Hurricane Tracking Models and the Role They Play in Forecasting Hurricances
Section 3: Hurricane Tracking Essentials Part 2
Lecture 3 Hurricane Computer Data: How to Read and Use It in Real World
Lecture 4 30 Hurricane Models and the Best Consensus Model to Use
Lecture 5 Live Hurricane Tracking with Live Storm
Lecture 6 Live Hurricane Tracking Example Part 2
Begining Weather students and those interested in learning about hurricane tracking
Meterology 401 Hurricane Tracking Workshop
Download [14 KB]
Meterology 101: Hurricanes [2022, MP4]
Oil Market Analytics Fundamentals [2021, MP4]
Weather & Meteorology - A Basic Understanding [2019, MP4]
How to Navigate with a Traditional Nautical Chart [2021, MP4]
TIG Welding Basics Part 1 [2020, MP4]
Non-Destructive Test (Welding Inspection) [2023, MP4]
Meteorology and weather - Basic understanding [2022, MP4]
Learning to Sail: A No-nonsense Guide for Beginners of All Ages - Learning to Sail: A No-nonsense Gu...
Learn Basics of Hydraulic Machines in the most easiest way [2021, MP4]
Learn to sail - Boulva K, Roux-groleau J.- P. [2010, PDF]
The time now is: Today 04:33
