gillnumil ®   27-Mar-2023 11:08
Guidance Notes for Class and Statutory Approval and Use of Marine Biofuels
Year: 2023
Author: Llyod's Registar
Edition: January
Pages count: 30
Description: This document provides guidance on the Class and Statutory requirements for use of so-called ‘drop-in’ liquid biofuels for marine and offshore installations, for use as direct replacements of, or as blends with, conventional petroleum derived residual (RM-grade) or distillate (DM-grade) fuel oils. Such biofuels should
comply with the ISO 8217 Petroleum products – Fuels (class F) – Specifications of marine fuels standard.
These guidance notes are applicable to ‘drop-in’ biofuels but not to the bio-derived gaseous fuels such as biomethane or liquid methyl/ethyl alcohol fuels that fall under the scope of IMO Resolution MSC.391(95) The International Code of Safety for Ships Using Gases or Other Low-Flashpoint Fuels (IGF Code).
Guidance_Notes_for_Class_and_Statutory_Approval_an_230217_091548.pdf
Download [881 B]
Guidelines on Use of Biofuels on Ships - Indian Register of Shipping [2023, PDF]
Requirements for Liquified Hydrogen Carriers - ABS [2023, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl/Ethyl Alcohol/LPG/Ammonia) - ClassNK [2024,…
Guide for Ammonia Fueled Vessels - ABS [2021, PDF]
Guide for Gas and Other Low-Flashpoint Fuel Ready Vessels 2024-Aug - ABS [2024, PDF]
IGF Code
Guidelines for Ships Using Alternative Fuels - ClassNK [2026, PDF]
Guidelines for ships using Low-Flashpoint Fuels (Methyl/Ethyl Alcohol / LPG) - NKK [2019, PDF]
International code of safety for ships using gases or other low-flashpoint fuels (IGF code) - ITF…
The time now is: Today 15:55
