tomado ®   29-Aug-2022 20:18
TimeZero Professional
Year: 2022
Version: 4.2.0.132
Developer: Nobeltec & MaxSea
System Requirements: The following system requirements must be fulfilled to run TimeZero v4 Navigator:
Microsoft® Windows® 7 SP1, or Windows® 8.1 or Windows® 101.5 GHz processor (Intel i5 recommended)4GB RAMVideo card:Minimum - Integrated Intel Graphic Chipset (HD Series)Recommended - Dedicated Graphics with 1GB VRAM or Intel HD 4th Generation or aboveScreen resolution: 1024 x 600 (1280 x 800 or higher recommended)Hard Drive: 30 GB free spaceA USB port or a Serial port for instruments using the NMEA183 protocol, an Actisense USB NGT-1 for those using the NMEA2000 protocol or a 100 Base-T Network Card for devices connected by Ethernet (such as the Furuno FA30, etc.)
Crack: Included
Description: Big thanks to all contributors from https://www.gpspower.net/ forum .
Installation instructions: On windows defender , allow The Keygen MaxLicV4Pro_R5. and MX_TZ v4PRO_crack_SplahScreen before downloading.
1.Turn off internet connection
2.start the installer "InstallProfessional v4.2.0.132 (build 4.2.186.0) Professional" ,when installtion completed uncheck the "Do you want to Run TimeZero" and close the popup window.
3.Run "MX_TZ v4PRO_crack_SplahScreen" and press continue. it will automatically close.
4.Run "Block Host.cmd" to avoid the UM code issue every time you execute TIMEZERO.
5.Run the keygen "MaxLicV4Pro_R5" and TZ4 application .
generate your serial number and put it on tz , press next you will see the SC code on the second window
copy paste in the keygen and generate the AC code.
Congratulation installation completed.
enjoy it.
Note: The keygen allow you to generate the chart serial key.
Full description
Supported operating systems: Windows 8.1 and Windows 10
Connection to instruments: NMEA0183, NMEA2000 or Furuno NavNet network (for navigation data only)
Autopilot Output Connection (2)
Exclusive TIMEZERO Map Engine (2D and 3D view)
Professional user interface
Touchscreen compatible user interface
"Quick Action" function (NavData): configure actions via a single button
Day, Twilight and Night Modes
World Map (base map)
3D World Database (base map)
Compatibility mm3d Raster or Vector maps (from different sources such as C-MAP or MapMedia)
Importing S57 Cards (NOAA ENC)
PhotoFusion TIMEZERO Exclusive (intelligent fusion between Satellite Photos and nautical charts)
Bathymetry (in color according to the depth indicated on the map)
Custom bathymetry (choice of colors according to depth) Optional
Profile window on ruler plot or boat trace Optional
Custom line outline Optional
World Tide Database
Tidal currents for North America
High Resolution tidal currents for Western Europe (to be consulted on the map catalogue) Optional
High Resolution Satellite Photos for the Bahamas and Europe (to be consulted on the map catalogue)
Undo & Redo function
Trace recording and customizable trace color (with trace recall function)
Variable color of the trace (depending on SST data, speed, depth...)
Advanced route planning (optimization of the departure time according to tidal currents)
Different categories of SAR (Search And Rescue) route
Anti-stranding cone (triggering a real-time alarm)
Safe Route Planning
Position Loss Alarm
Impression of road characteristics
NavData counter (Duration, Distance, Maximum speed, Average speed)
Marks, Waypoints, Routes, Areas, Line, Annotations and Photos (user data)
Synchronization of user data (local and cloud synchronization) with all TIMEZERO compatible devices
Marks, traces and unlimited areas
Layer and marker management (with presets allowing the user to create a layer "group")
Advanced event management
Event grid accessible from Navdata
Loran C & Decca Grid
Worldwide Location Search Tool
Import your own photos with Automatic Geolocation
POIs: ActiveCaptain (Interactive Cruise Book))
Meteorological data service (rain, clouds, air temperature, wind, waves, geostrophic currents, pressure)
Ocean Data Service (Surface Temperature, Plankton, Altimetry, etc.)
Ocean-O Premium Oceanographic Data Service (high-resolution weather forecast, multiple data layers, and preset filters) Optional
Animation of weather forecasts, tides and currents
Alarms (Mooring Alarm, CPA/TCPA, Depth Alarm, and more)
A NavData of the alarm area (to know at any time the situation of the nearby alarm zones)
An alarm zone can also be configured and triggered when AIS and ARPA targets enter that zone
Display of AIS and MARPA targets (with list of targets)
Display of the CPA of AIS and MARPA targets
Recording the trace of targets
Automatic display of target trail
Advanced AIS Target Management (Target Activation)
AIS MKD allowing to configure an AIS transponder from the software (Voyage status: docked, navigation ...)
AIS messages can be sent and received
Compatibility with AIS Marine Traffic online targets (Source AIS via an Internet connection)
Digital Selective Calling (ASN) and Man overboard (MOB)
Fleet tracking (support for "PosRep" files)
Fishing buoys
Support AXIS IP Cameras and Video Converter (Control and Tracking)
Integration of FLIR Thermal Cameras (M-Series, Control and Tracking)
H264 generic fixed network camera (video only, no control or tracking)
Augmented reality
Up to 3 monitors can be used
Fuel management (fuel level, Road alarm, Distance to exhaustion, Time to exhaustion)
High Resolution 3D Bathymetry (on selected area only) Optional
Optional modules:
TZ Professional v4
The TZ Radar Module (with Furuno Ethernet Radar) includes:
Connection to the DRS and FAR radar network (to view and control the radar)
Shared map licenses with NavNet MFDs
Synchronization of user objects and active route between Navnet TZtouch2 (v7) and TZtouch3
Full Screen Radar workspace and Radar Overlay
ARPA algorithm available in TZ with automatic acquisition of ARPA targets (surveillance zone)
The Sonar Module (with Furuno Ethernet Sonar) includes:
Optional
Connecting to the sonar's network (to view and control the sonar)
"Full Screen" Sonar workspace with echogram history
The Routing Module includes:
Optional
Routing according to wind, waves and currents
Isochrones with overlay wing (SailSet)
Routing algorithm automatically bypassing coasts and shallow waters (ability to configure the limit depth)
Mixed sail/motor routing (depending on the wind and the theoretical speed limit)
Display of wind barbs at each stage of routing
Alternative Routing
Routing Detail (List)
Routing Animation
Laylines (requires a wind sensor)
Polar Workspace: to view and edit wind data and sail fleece
Change in polar in %
Adjusting Weather Files
Calculating and Displaying Routing Variability
The TZ PBG Module includes:
Optional
Fishing workspace to customize bathymetry and probe lines
Dynamic extrapolation (more accurate and faster)
Display of the "3D" workspace
The WASSP Multibeam Sonar Module (3)
Optional
Connection WASSP G1 or WASSP G2 or WASSP G2 survey or WASSP G3
Saving Depth Data and BackScatter
Navigation data (not available with WASSP G1)
Different display modes in workspaces: Section, Multibeam, Side Scan, or Water Column (available only with the WASSP G3)
The DFF3D Multibeam Sonar Module (3)
Optional
Connection to the DFF3D multibeam sonar
Different display modes in TIMEZERO such as Section Workspace, Multibeams, Water Column or Side Scan
The Trawl Positioning Module
Optional
Connection to the Marport trawl positioning system (system with a single net and two doors)
Direct display on the mesh map in 2D and 3D mode
Display of the trace and vectors of prediction of the doors
Background hardness modulus (3)
Optional
Recording (via NMEA0183) of the hardness of the bottom at the output of the sonars:
Simrad ES70 and ES80 ($PSIMDHB sentence)
Koden CVS-FX series ($PKODS sentence)
Hondex HE-7300 Di and HE-1500 Di ($PHDX sentence)
JRC JFC-130 series ($PJRCS sentence)
Seascan ($PSAP sentence)
The VDR module (Voyage Data Recorder)
Optional
The S63 ENC Module
Optional
Notes:
(1) - The TZ Professional license gives access to a default installation
(2) - Connection to the driver can be via NMEA0183 (via serial COM port) or NMEA2000 (via Actisense NGT1-USB gateway).
(3) - The WASSP and DFF3D modules require the prior acquisition of the PBG module
TimeZero Pro V 4.2.0.132
aphix   18-Sep-2022 16:22
Есть возможность установить карты Баренцева, Карского моря? / Is it possible to install maps of the Barents, Kara Sea?
5
kadoka   20-Sep-2022 22:02
MWVJRSM001MAP21.1
WVJRSM202MAP21.1
Copy and past in search position after that you will see the charts.
3
Guest   28-Sep-2022 21:51
Какие карты можно взломать при помощи этого кряка?
aaaa34480   28-Sep-2022 21:52
Guest   02-Oct-2022 06:14
there is no connect with the internet,it can not shown any AIS
recycle   02-Oct-2022 09:51
Guest, your hosts file should contain this rows:
127.0.0.1 mytimezero.com
127.0.0.1 login.mytimezero.com
127.0.0.1 extranet.mytimezero.com
127.0.0.1 www.nobeltec.com
127.0.0.1 www.maxsea.com
C:\Windows\System32\drivers\etc\hosts (need to open hosts file with administrator rights). Do not use firewall to block TimeZero from Internet access.
9
ngiann   13-Oct-2022 19:22
Just for your information, i had successfully installed it in an old low cost PC.
Specifications:
Windows 7 Ultimate 64bit - Service Pack 1
Intel Atom 330 1.6Ghz
4Gb RAM
GPU: NVIDIA ION
Tried on normal 2.5" Hard Disk but on SSD seems to run faster.
I use a low cost USB GPS receiver from Aliexpress.
Program runs relatively smoothly.
3
a_koseoglu   15-Oct-2022 19:23
Dear All ,
After all procedure i am starting programbut can not see SC code.. What is the problem.. All looks OK but Time Zero giving me error.. No SC Code ???
3
Gian007   23-Oct-2022 00:47
It does not work.
It can not calculate the AC code as you can see in the pic attached.
Attachments Image 2.pdf (372 KB, Downloaded: 1510 times)
7
pepejoe10   27-Oct-2022 23:11
thank you so much bro for the program ,, i want to ask you about if i can activate internet or not to use TZ pro
noael   01-Nov-2022 00:04
i have trouble installing it on a mac book M1 using Parallel desktop. did someone mange to get it working on a mac book?
pepejoe10   03-Nov-2022 00:42
how can i activate OCEANGRAPHIC DATA included clorophyll and sea surface tempreature ??
8
Navionics Boating v.10.7.1 - Navionics [2017] [iOS]
NACOS Platinum Integrated Navigation System Operations Manual(Wärtsilä SAM Electronics) - SAM…
SAS.Planet ( SASPlanet ) v.200114.1.107 - sasgis.org [2020]
Maris ECDIS900 Operator Manual - Navico Holding AS [2017, PDF]
MarineTraffic v.4.0.46 - MarineTraffic [2023] [Android]
ChartBrowser v.2.4.6.8 - ChartWorld [2018]
MarineTraffic Mod Apk Latest Update v.3.9.56 - Marine Traffic [2020] [Android]
Ship Radar CRT Simulator (Radar Trainer) v.4.0102 - LightMaster [2000]
EIVA NaviScan v.9.7 - EIVA [2022]
The time now is: Today 14:17
