twicer ®   25-Aug-2022 11:57
Coastal Navigation : a programmed learning course
Year: 1988
Author: Gerry Smith
Publisher: Adlard Coles
Edition: 3rd
ISBN: 0229117090
Pages count: 190
Description: This book has been written with the needs of the small boat sailor very much
in mind and the material is focussed on the person who frequently sails
coastwise around the shores in a boat no longer than, say, a 30-footer.
Sea-anglers and sub-aqua sportsmen, in addition to sailors, should get sound
advice and teaching from it. The only starting qualifications this programme
asks of you is that you can add, subtract, multiply and divide simply numbers
and that you will accept that the earth is, roughly speaking, spherical.
This publication ‘teaches’ because it gives you the chance to make mistakes
and then guides you to a better understanding of the causes of them. If
you are very competent it is possible that you can do the programme in a
shorter time than usual because you are not required to do all the pages; you
obviously will not make many mistakes. But if you do get wrong answers — and
everyone does at some time or other — the course is designed to channel you
to ‘back-up’ material which should help to set you back on the correct course.
Coastal navigation a programmed learning course.pdf
Download [4 KB]
The Sailing Bible - The Complete Guide for All Sailors from Novice to Experienced Skipper - Jeremy…
A Seafarer’s Financial Compass-How To Multiply Your Income While You Are Still A Seafarer -…
Pronounce it Perfectly in English - Yates, Jean [2005, PDF]
Sailing - A beginner’s guide - Seidman D. [2011, PDF]
The Sailor’s Sin Bin - Cruisers Confess to their Boating Blunders - Stocker T. [2022, PDF/EPUB]
Celestial Navigation, A Practical Guide to Knowing Where You Are - Dave Berson [2018, EPUB]
Inshore Navigation - Tom Cunliffe [2008, PDF & Doc]
Coastal Turmoil - Endean K. [2010, PDF]
Sails Sixth edition - Jeremy Howard-Williams [1988, PDF]
Details of classic boat construction - the hull - Pardey L. [1991, PDF]
The time now is: Today 18:12
