linbs ®   14-May-2022 13:54
Mobile Solar Power Made Easy
Year: 2018
Author: William Errol Prowse IV
Edition: 1
ISBN: 978-1546567110
Pages count: 91
Description: A solar panel will produce electricity, a battery will store electricity and a set of appliances will consume electricity.
Electricity travels in wires, or conductors, to transfer energy across distance. 2 wires are required to carry electrical
force from one location to another.
Electrical energy can be carried in two ways:
-Direct Current (DC Power): The flow of electricity is direct and flows like a river. It comes in one wire and flows out the second wire. One wire is positive, one wire is negative. The differentiation of the positive and negative wire is called the polarity and refers to the electrical charge present in the wires which are used to transmit electrical force.
-Alternating Current (AC Power): Unlike DC, the electrical force in an AC circuit does not flow, but instead vibrates back and forth to carry energy. Imagine how ocean waves can transmit energy over vast distances, without moving the water. Same concept. There is no positive or negative wire in an AC circuit.
Instead, the polarity or electrical charge in the wires is constantly alternating.
Alternating current is more efficient than direct current over long distances, but direct current is required if you plan to store the electricity in a battery. Appliances can be designed to use DC or AC power. Some motors and lights can be powered with AC power, but most AC appliances transform the AC electricity into DC electricity, mwhich is much more versatile.
AC electricity is great for sending electrical energy over long distances, and DC electricity is versatile and easy to put to work.
In a solar power system:
-Solar panels produce DC electricity that travels through 2 wires and is stored in a battery.
-DC powered appliances are then connected to the battery with 2 wires so that they will consume the stored electricity in the battery and put it to work.
-If you plan to power AC appliances with a DC battery, you will need to transform DC electricity into AC electricity with a device called an inverter. More on this in a bit.
Download [9 KB]
Off Grid Solar Power - Tyler J. Green [2021, EPUB]
Off Grid Solar Power Handbook: 12 Volts Mobile Solar Power for RVs, Boats, Vans, Campers, Cabins…
Off Grid Solar Power Simplified - For Rvs, Vans, Cabins, Boats and Tiny Homes - Seghers N. [2020,…
Solar and 12-Volt Power Beginner’s Guide - The Complete Manual to Off Grid Solar Power System…
Basic Electrical Engineering | Synchronous Generator - Tinesh Mahajan [2021, PDF]
Off Grid Mobile Solar Power Installation in 1 Hour - A Step by step Guide to Design and install 12…
Off Grid Solar Power - A Simplified DIY Guide to Design and Install a Mobile Solar System - Tyler…
Design and Dynamic Modeling of a Solar Electric Boat Power System - Abdullah Al Mehedi M.A. [2021,…
Essential Boat Electrics - Carry Out Electrical Jobs On Board Properly & Safely - Manley P. [2021,…
Solar Power - The beginner’s guide on how to design and install a photovoltaic system for your…
The time now is: Today 15:02
