wxwship ®   28-Apr-2022 09:46
MAN ES (Basic Principles of Ship Propulsion)[2018, PDF]
Year: 2018
Author: MAN ES
Genre: Technical book
Pages count: 68
Description: This paper will explain the most elementary terms used regarding ship types, dimensions and hull forms, and clarify some of the parameters pertaining to hull resistance, propeller conditions, and main engine capabilities. The interdependencies between these illustrate the complexity of optimising the hull as well as the interaction with the propulsion plant. Based on the explanations given, the reader will be able to work through the engine selection spiral introduced in this paper. This will facilitate selection of the right main engine(s) for the right hull in order to support the ambition of creating a sustainable future.
Download [4 KB]
Basic Principles of Ship Propulsion - MAN [2018, PDF]
Basic Principles of Ship propulsion - MAN Energy Solutions [2023, PDF]
Basic Principles of Ship Propulsion - MAN [2013, PDF]
Shaft generators for low speed main engines - MAN [2012, PDF]
Propulsion Trends in Container Vessels - MAN Diesel & Turbo [2013, PDF]
Design of Propulsion and Electric Power Generation Systems - Woud H.K, Stapersma D. [2003, PDF]
Lecture Note for Innovative Ship Design - Prof. Kyu Yeul Lee [2012, PDF]
Ice Classed Ships Main Engines - MAN Energy Solutions [2022, PDF]
Braemar SA - Guide to Hull and Machinery - Technical Terms - Braemar Technical Services Ltd [2015,…
Improved Efficiency Propulsion Plants - MAN Energy Solutions [2022, PDF]
The time now is: Today 18:11
