marlamamba ®   15-Mar-2019 19:48
Basic Principles of Ship Propulsion
Year: 2018
Author: MAN
Genre: Handbook
Publisher: MAN Energy Solutions
Pages count: 35
Description: This paper will explain the most elementary terms used regarding ship types, dimensions and hull forms, and clarify some of the parameters pertaining to hull resistance, propeller conditions, and main engine capabilities. The interdependencies between these illustrate the complexity of optimising the hull as well as the interaction with the propulsion plant.
Based on the explanations given, the reader will be able to work through the engine selection spiral introduced in this paper. This will facilitate selection of the right main engine(s) for the right hull in order to support the ambition of creating a sustainable future.
Additional info: New 2018 edition
Basic Principles of Ship Propulsion.pdf
Download [9 KB]
Basic Principles of Ship propulsion - MAN Energy Solutions [2023, PDF]
Basic Principles of Ship Propulsion - MAN [2013, PDF]
Improved Efficiency Propulsion Plants - MAN Energy Solutions [2022, PDF]
Ice Classed Ships Main Engines - MAN Energy Solutions [2022, PDF]
Lecture Note for Innovative Ship Design - Prof. Kyu Yeul Lee [2012, PDF]
Propulsion Trends in Container Vessels - MAN Diesel & Turbo [2013, PDF]
Propulsion Trends in Bulk Carriers - MAN Energy Solutions [2024, PDF]
Design of Propulsion and Electric Power Generation Systems - Woud H.K, Stapersma D. [2003, PDF]
Shaft generators for low speed main engines - MAN [2012, PDF]
Guidelines for The Design and Operation of Dynamically Positioned Vessels - IMCA [2016, PDF]
The time now is: Today 14:17
