deepseabulb ®   16-Feb-2022 21:54
Comprehensive Stability for OIM, Barge Supervisor & Ballast Control Operator
Year: 2021
Author: Maersk Training
Genre: Lections
Number of pages: 150
Description: Comprehensive Stability course with Home work & Reflection Exercises.
Per the regulations of 46 CFR 11.470 and meets all requirements listed under the International Maritime Organization (IMO). Resolution A.1079(28), and STCW Convention Regulations I/10 & I/02 - MODU Stability - for the training of OIM, Barge Supervisor, Ballast Control Operator (OIM / BS / BCO).
5 day course
LEARNING OUTCOMES
I. Knowledge of and ability to apply relevant international and national standards.
1. Basic Units and Definitions
Systems of Measurement (Metric, Imperial and US Customary units)
Quantities and Measurements for Stability Calculations
Definitions
II. Use of loading/stability information from trim and stability diagrams and marine operations manual.
1. Hydrostatic properties
Hydrostatic Property Information
Draft
Displacement
Height of the Centre of Buoyancy (KB) or Vertical Centre of Buoyancy (VCB)
Longitudinal Centre of Buoyancy (LCB) and Transverse Centre of Buoyancy (TCB)
The Waterplane Area (WPA)
Tons Per Inch (TPI)-Tonne per cm (TPC)
Longitudinal Centre of Flotation (LCF) and Transverse Centre of Flotation (TCF)
The Height of the Longitudinal Metacentre (KMI) and Transverse Metacentre. (KMt)
Moment to Heel or Trim 1° (MH1°-MT1°). Moment to Trim or Heel 1 cm (MCT-MCH)
2. Free surface effect
The Free Surface Effect on Stability
Calculation of the Loss of GM caused by the Free Surface Effect
The effect of added bulkheads in tanks on the Free Surface Effect
The Tank Tables with Free Surface Moment
Wet and Dry GM
3. Stability calculations on board
Loading Conditions
The Mooring System Correction
The Maximum Allowable Area Loading
The Stability Calculations on Daily Report Forms
Tank Capacity Tables and Curves
III. Understanding of fundamental principles-theories-factors affecting trim and stability to preserve trim and stability and measures to preserve trim and stability.
1. The centre of gravity, the centre of buoyancy, and the metacentre
The Centre of Gravity (G)
The Centre of Buoyancy (B)
The Metacentre (M)
The Height of the Metacentre (KM)
The Stability Couple
The Metacentric Height (GM)
The Righting Arm (GZ)
The Righting Moment
Heeling and Lolling
Hog and Sag
Stable Equilibrium
Neutral Equilibrium
Unstable Equilibrium
Stiff and Tender
Rolling Period
Transverse Versus Longitudinal Stability
Categories of Stability
2. Change of draft, heel, and trim
Mean Draft (MD)
True Mean Draft (TMD)
Change of Draft (COD)
Change of Trim (COT)-Change of Heel (COH)
IV. Static and dynamic stability criteria for MOUs, environmental limits, and criteria for survival conditions.
1. The calculations for Centre of Gravity (G), Centre of Buoyancy (B) and Metacentre (M)
The Effect of Weight Shifts on the Centre of Gravity (G)
Recapitulation of Shift of Centre of Gravity
The Position of the Centre of Buoyancy (B) and the Metacentre (M) in Relation to K
The Effect of Draft on the Centre of Buoyancy (KB)
Inertia
Calculation for BM
Calculation for GM
Calculation for List and Trim in Degrees
Summary of Static Stability for Small Angles
2. Stability at large angles-stability curves
Intact Statical Stability Large Angles
The Curve of Statical Stability
The Cross Curves of Stability
Use of Cross Curve of Stability
The Curve of Righting Moments
Dynamic Stability
Damage Stability
Basic Damage Stability Procedures
The Down-Flooding Angle
The Maximum Allowable Vertical Centre of Gravity (VCG)
V. Understanding of inclining experiment, deadweight, and their use
1. The Inclining Experiment
The Preparation of the Inclining Experiment
The Principle of the Inclining Experiment
The Inclining Experiment Calculation
Lightship and variable loading
Tracking cumulative changes to lightship condition.
VI. Use of daily loading calculations.
VII. Knowledge of the Effect of:
1. Trim and stability of MOUs in event of damage and consequent flooding and countermeasures.
Effects of tanks or spaces open to the sea and free communication between tanks or spaces within the unit
2. Movement or off loading supplies or equipment and ballasting of MOUs in order to keep the unit's stress within the acceptable limits. Should include basic discussion/explanation of the following:
Forces Working on the Floating Unit
Stress, Strain, and Yield
Fatigue
Shear Stress
Sagging and Hogging
Design Loading Conditions
Steel Quality and High Strength Steel
Member Loading and Stress
Fatigue in Members and Connections
Load Curves on Drilling Vessels
Preloading and leg stresses on Jackups
3. Mooring system.
Mooring System Components & Purpose
The Anchor System Correction
Use of Catenary Curve Tables
Vertical Component of Line Tension
Lightweight Correction for Deployed Chain
Environmental Forces & Offset
Effects of Line Failures
4. Loss of buoyancy
Definition of Damage Stability
Causes of Damage Stability
Consequences of Damage Stability
Permeability
Reserve Buoyancy and Damage Stability
Watertight Integrity
Calculation of Damage Stability
The Added Weight Method
The Lost Buoyancy Method
Comparison Between Added Weight and Lost Buoyancy Methods
The Stability Curve for Damage Stability
Damage Control Procedure
Damage Stability Calculation on Board
VIII. Knowledge of:
1. The emergency response for flooding due to damage, fire fighting, loss of buoyancy, and the effect on trim and stability.
Hazards Associated with Counter Flooding
The Down-Flooding Angle.
2. Countermeasures for damage stability
3. Effectively communicate stability-related information.
Loading Conditions
4. Environmental Considerations - Pollution Prevention
Download [31 KB]
DZHermes   17-Feb-2022 00:18
Maersk Trainings is great and informative. Looking forward for more new trainings....
Advanced Stability - The University of Texas at Austin [2006, PDF]
Basic Electrical Installation Work - Level 2, 9th Edition - Trevor Linsley [2019, PDF]
The ECDIS Manual (2019 Edition) - Witherby [2019, PDF]
STCW Convention - IMO [2011, PDF]
Test Item Bank for Deck Officer and Engineer Officer at Operational level - DPKP [2018, PDF]
Basic Electricity and Electronics for Control: Fundamentals and Applications - awrence M. Thompson, ...
Survey guidelines under the harmonized system of survey and certification (HSSC) - IMO [2025, PDF]
Radar Navigation Course at Operational & Managerial level (in accordance with IMO model courses 1.07...
Training Manual Volume I-IV - D.G. Shipping, India [2025, PDF]
The time now is: Today 03:27
