Knot Tying for Beginners - An Illustrated Guide to Tying 65+ Most Useful Types of Knots
Year: 2021 Language: english Author: McCoy M. Genre: Manual Publisher: McCoy M. ISBN: B09H3PM8B4 Format: PDF Quality: eBook Pages count: 213 Description: Have you ever found yourself needing to tie something but did not know how to? Probably all you could do was a weak, messy knot similar to the one you use to tie your shoes. Don't worry! We got you covered. Often, knowing how to tie a knot properly can be very important. A knot incorrectly tied might loosen and break something, or in the worst-case scenario, it might even hurt someone. There's a knot for every situation, and knowing at least the most common and effective ones is key. That's why we decided to list more than 65 of the most common knots and illustrate step-by-step how to tie each of them for you to learn. Inside Knot Tying for Beginners you'll discover:
How to properly tie 65+ knots from the easiest to the hardest
Illustrations and pictures of each step to take to tie every knot perfectly
Explanations, descriptions, uses, history, pros and cons of every knot
The knots are all listed in different chapters for every situation to easily find them ..and much, much more! You'll learn all the secrets of a perfect knot through more than 800 illustrations that explain everything you need to know to tie a knot that can't possibly loosen. You'll be surprised about how easy it will be to understand and learn all the knots from basics, boating, fishing, stopper knots, end loops, and much more! It's always better to know a knot and not need it than need a knot and not know it.
Author: McCoy M.
Publisher: McCoy M.
ISBN: B09H3PM8B4
Pages count: 213
Notice from: gillnumil
https://seatracker.me/viewtopic.php?t=51790
McCoy M. Knot Tying for Beginners, 2021.pdf
Download [9 KB]
Share
