vitbar192 ®   06-Jul-2021 06:30
The Ultimate Guide To Knots - The Step-by-Step Guide To Tying The Perfect Knot - How To Tie Basic Knots
Year: 2021
Author: Perkins B.
Publisher: Outdoors
Pages count: 58
Description: Knot tying has always been one of those key outdoor skills that the inexperienced take for granted. The experienced outdoorsman, however, has had enough success and failure to know that there are right and wrong knots for certain jobs.
But first, it helps to know a few strange terms. Put it simply, a knot is some kind of fastening or splice made by intertwining one or more ropes or some other flexible material. After tightening a knot, it should hold on its own. A hitch is a little bit different. It’s like a knot, but it generally involves another object like a stick, a post, a ring, or occasionally another rope. Properly tied, hitches can hold their place, or they may be able to slide, depending on the hitch you choose. A lashing is like a hitch, but slightly more complex. Lashings involve the use of a rope or similar material to secure two or more objects together. To grossly oversimplify all this, the knot is just rope fastened together; the hitch is a rope fastened to an object; and a lashing is a rope fastening multiple objects together.
A good knot can save lives when you're dealing with a survival situation, performing first aid, and when working over heights or water. But, you have to know how to tie it. So make sure you know what to do with your rope the next time you head into the wild by learning these 20 essential knots.
Perkins B. The Ultimate Guide To Knots, 2021 .pdf
Download [15 KB]
Basic Knots and Hitches: Ways to Tie Essential Knots You Should Know - macmillan [2021, PDF]
The Guide Book Of Knots: How to Tie Basic Knots With Detail Instructions - Smithson Heather [2022, E...
How to Knot Step by Step - Detail and Simple Knotting Guide Book for Beginners - Outdoors [2021, PDF...
Essential knots - Macwelch T. [2019, PDF/DOCX]
Tying Different Types of Knots - Essential Knots You Should Know - Outdoors [2021, PDF]
Tying Knots for Beginners - How to Tie Types of Knots for Beginners - Essential Knots You Can Do - O...
Knots Tutorials: How to Knot Properly for Beginners - Parden Jessie [2021, EPUB/PDF/AZW]
The Field Guide to Knots - Holtzman B. [2015, EPUB]
Ropes, Knots, and Hitches - Buck Tilton [2019, EPUB]
40 Knots and How to Tie Them - Davidson L. [2018, EPUB]
The time now is: Today 13:30
