Ferreirolo ®   06-Dec-2021 18:19
Competence of remote control centre operators
Year: 2021
Author: DNV
Genre: Convention (rules)
Publisher: DNV AS
Edition: 1
Pages count: 32
Description: The standard covers the tasks performed by a remote control centre operator (RCCO) in a remote control centre (RCC) for the monitoring and control of autonomous, remotely operated and remotely supported vessels and , identifies a base set of competencies. The standard aims to provide guidance for establishing a competence foundation, to be supplemented by e.g. operational/supplier manuals and system specific details.
With digital and remote solutions available, tasks may be performed where it is most effective to perform them - this may be on board or ashore and tasks and functions may be moved either or both ways. Also,
the scope of monitoring, control and support for a vessel may vary. The physical RCC may therefore take
the form of a comprehensive control room but may also consist only of a limited set-up, where defined information is displayed for vessel sub-systems, based on which the RCCO supports a crew on board. An RCC may monitor/support/control more than one vessel.
The competencies listed in this standard will be amended frequently to accommodate new competencies evolving together with technological and organizational changes to the operation of autonomous, remotely operated and remotely supported ships.
Additional info: The new type of OOW and shiphandling is explained here. Future is now and here
DNV-ST-0324.pdf
Download [507 B]
Insights into Vessel Connectivity - ABS [2022, PDF]
Operator’s Manual for Engine Room Simulator ERS L11 5L90MC VLCC (Version MC90-V) - Kongsberg [2009,…
Guide for Autonomous and Remote Control Functions - ABS [2021, PDF]
Code of Safe Working Practices for Merchant Seafarers - MCA [2021, PDF]
Autonomous and remotely operated ships - DNV [2018, PDF]
SAAB Transponder System R4 AIS Operators Manual - SAAB [2006, PDF]
Reducing The Risk of Incidents Due to Systematic Failure - The London P and I Club [2020, PDF]
Recommendations for Cargo Control Room HMI - SIGTTO [2021, PDF]
The Workboat Code - Maritime and Coastguard Agency [2023, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl/Ethyl Alcohol/LPG/Ammonia) - ClassNK [2022,…
The time now is: Today 15:11
