twicer ®   02-Nov-2021 14:35
Application of Higher-Strength Hull Structural Thick Steel Plates in Container Carriers
Year: 2021
Author: ABS
Genre: Technical book
Pages count: 135
Description: Over the last several decades, the drive for increasingly efficient sea-borne container
transportation has led to significant growth in the size of container carriers. Application of hull structural
thick steel plates in the upper flange of large container carriers is a natural choice for the hull structure
to meet the required hull girder strength. Steel plates well in excess of 50 mm (2 in.) in thickness are
commonly found in large container carriers.
This Guide provides the requirements for the optional notation, EBCAD (Enhanced Brittle Crack Arrest
Design), for the enhanced BCA application of higher-strength hull structural thick steel plates in container
carriers.
This edition also updates the requirements for H47 steel and brittle crack arrest steel and introduces a new
Appendix 8 on engineering critical assessment for hatch coamings.
Release Date: February, 2021
Higher-Strength Hull Structural Thick Steel Plates in Container Carriers ABS 2021.pdf
Download [7 KB]
Requirements for Application of Higher-Strength Hull Structural Thick Steel Plates in Container Carr...
Guide for Implementation of International Safety Guide for Oil Tankers (ISGOTT) - ABS [2017, PDF]
Torsion and Shear Stresses in Ships - Mohamed Shama [2010, PDF]
Rules of Korean Register of Shipping - KR [2018, PDF]
Guide for Special Loading of Ore and Ore/Oil Carriers - ABS [2023, PDF]
Guidelines for Strength Assessment of Lashing Bridges - ClassNK [2026, PDF]
Guide for Bridge Design and Navigational Equipment - ABS [2022, PDF]
Guide for Slamming Loads and Strength Assessment for Vessels - ABS [2021, PDF]
The time now is: Today 00:38
