lb007 ®   09-Sep-2021 11:28
CBM Guidelines - ClassNK
Year: 2021
Author: ClassNK
Genre: Technical book
Publisher: ClassNK
Edition: 2nd
Quality: Unknown
Pages count: 52
Description: Leading Classification Society ClassNK released its CBM Guidelines (Edition 2.0) that explain the revised rules for using Condition Based Maintenance (CBM) in class surveys to promote the use of CBM technology.
From safe operation and operational cost reduction perspectives, Condition Based Maintenance (CBM) has been attracting more attention. Under such circumstances, ClassNK amended CBM its CBM rules in 2020 specifying requirements for incorporating modern CBM in surveys. ClassNK also published its CBM Guidelines (First Edition) in 2019, which clarify required documents and the approval procedure for substituting CBM in place of periodical overhaul inspection for class maintenance surveys.
As a reference to select equipment and methods for CBM, the revised guidelines contain case studies based on risk evaluation of CBM implementation in consideration of cost efficiency as well as comparisons between CBM surveys and conventional surveys. These case studies reflect the outcomes obtained through joint research with the shipping company and engine manufacturer and can be utilized as the guidance for the introduction of CBM powered ship management.
Further, they introduce investigation results and proposals for promoting the use of CBM, developed by a “CBM study team” joined by diesel engine and other manufactures and industry parties of IoS-OP consortium*1, along with a general explanation and future outlook on CBM.
ClassNK will continuously explore ideal safety through R&D with partners spearheaded by front runners of new technologies such as CBM, and at the same time, contribute to the spread of new technology and the realization of ship safety by setting regulations based on the knowledge obtained.
The guidelines are available to download free of charge via ClassNK’s website www.classnk.com for those who have registered for the ClassNK “My Page” service. To register for the “My Page” service free of charge, go to the ClassNK website www.classnk.com and click on the “My Page Login” button.
*1 Internet of Ships Open Platform (IoS-OP)
A universal platform that enables the sharing of ship operation data among shipbuilders, manufacturers, and related service providers without compromising profits of data providers. Under the IoS-OP consortium composed of member companies, IoS-OP is run by ShipDC, a subsidiary of ClassNK.
CONTENTS
Chapter 1 General ·········································································································· 1
1.1 Maintenance Method ............................................................................................ 1
1.2 Planned Machinery Survey .................................................................................. 3
1.3 CBM for Ships ....................................................................................................... 4
Chapter 2 Condition Based Maintenance (CBM) Schemes ···················································· 7
2.1 Application of CBM Scheme (for ship management company) ........................... 7
2.2 Surveys under the CBM Scheme ........................................................................ 12
2.3 Condition Monitoring Systems ........................................................................... 14
Chapter 3 Guidelines for Selecting the Concerned Machinery and Equipment and Methods for
Condition Based Maintenance ···························································································· 16
3.1 Concerned Machinery and Equipment for Condition Based Maintenance ...... 16
3.2 Condition Based Maintenance Methods ............................................................ 19
3.3 Considerations when Adopting a CBM Survey Scheme .................................... 23
Chapter 4 Future Prospect ······························································································ 24
4.1 Future Initiatives of the Society ......................................................................... 24
4.2 IACS Unified Requirement(UR) Z27 .................................................................. 25
Appendix 1 Amendment of the Rules (Extract) ································································· 26
Appendix 2 Introduction of IoS-OP Consortium CBM Discussion ········································ 38
CBM Guidelines 052021.pdf
Download [4 KB]
Guidelines for Remote Survey - ClassNK [2025, PDF]
Guidelines for Remote Survey - ClassNK [2021, PDF]
Guidelines for remote Survey - ClassNK [2021, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl / Ethyl Alcohol / LPG / Ammonia) - ClassNK…
Rules for the Classification Surveys of Ships in Service with Annexes - RMRS [2020, PDF]
Rules for the Equipment of Sea-Going Ships - Russian Maritime Register of Shipping [2020, PDF]
Rules and Guidelines of China Classification Socirty (CCS) - CCS [2018, PDF]
ClassNK Technical Journal No.8 2023(Ⅱ) - ClassNK [2023, PDF]
DP Operations Guidance - Dynamic Positioning Committee [2021, PDF]
Guidance for safe return to port projects - DNVGL [2016, PDF]
The time now is: Today 15:56
