twicer ®   08-May-2021 03:33
Cyber Security for Ports and Port Systems - Good Practice Guide
Year: 2020
Author: IET
Pages count: 71
Description: This Good Practice Guide is a revision of an earlier code of practice on cyber security, published by the Department for Transport (DfT) in 2016. The guidance was developed following visits to several UK ports by the authors and personnel from the Defence Science and Technology Laboratory (Dstl). Since this Guide was originally published in 2016, the Network and Information Systems Directive (the NIS Directive) has been implemented in the transport sector, following the coming into force of the UK implementing legislation (the NIS Regulations) on 10th May 2018.
This Guide considers the cyber security requirement at both ports and port facilities, advocating a coherent, port-wide based approach. It is intended to complement the port security standards and their respective requirements by providing additional guidance on the cyber-related aspects of the security measures set out. It therefore makes extensive reference to, and assumes knowledge of, the definitions and concepts contained within those requirements.
Who should use this Good Practice Guide?
This Good Practice Guide is intended for use by those with responsibility for protecting the port/port facility, ships (when docked or berthed), persons, cargo, cargo transport units and ships' stores within the port from the risks of a security incident.
Cyber Security for Ports and Port Systems_GPG 2020.pdf
Download [4 KB]
Cyber Security Code of Practice for Ships - Department for Transport, UK [2023, PDF]
A Guide To Good Practice On Port Marine Operations - UK - Department For Transport [2013, PDF]
Code of Practice Cyber Security for Ports and Port Systems - Hugh Boyes, Roy Isbell and Alexandra Lu...
A Guide to Good Practice on Port Marine Operations - UK - Department For Transport [2018, PDF]
Collection of European Legislation - Maritime affairs - EU [2013, PDF]
Cybersecurity in the Maritime Sector: Guidelines for Navigating Cyber Risk - ENISA [2020, PDF]
SIP 010 – GUIDANCE ON RO-RO AND STO-RO - Port Skills and Safety [2019,pdf] - Port Skills and Safety ...
Guidance on Mooring - Port Skills and Safety [2010, PDF]
The Guidelines on Cyber Security onboard Ships - BIMCO [2016, PDF]
Guidelines for Offshore Marine Operations - OCIMF, IMCA, MSF, and others [2025, PDF]
The time now is: Today 03:48
