Ferreirolo ®   25-Nov-2020 23:30
A Guide to Good Practice on Port Marine Operations
Year: 2018
Author: UK - Department For Transport
Publisher: UK - Department For Transport
Pages count: 195
Description: This document is intended to supplement the Port Marine Safety Code. It contains useful information and more detailed guidance on a number of issues relevant to the management of ports and other marine facilities.
The Code and this guide are applicable both to statutory harbour authorities and to other marine facilities which may not necessarily have statutory powers and duties. These are collectively referred to in the Code as ‘organisations’, and may include, but not be limited to, the following examples:
●● Competent Harbour Authorities (authorities with statutory pilotage responsible for managing a pilotage service)
●● Municipal Port or Harbour Authorities
●● Trust Port or Harbour Authorities
●● Private Port or Harbour Authorities
●● Marine berths, terminals or jetties
Whilst applicable to all ports the guide should be applied reasonably and proportionately to each port. It is designed to provide general guidance and examples of how an organisation could meet its commitments in terms of compliance with the Code. This Guide should not be viewed as the only means of complying with the Code and for some organisations; it may not be the best means of achieving compliance.
Additional info: Older release 2013:
A Guide To Good Practice On Port Marine Operations - UK - Department For Transport [2013, PDF]
Author: UK - Department For Transport | Year: 2013 | Language: english | Format: PDF | Quality: eBook | Pages count: 189 | Publisher: Department For Transport (UK)
Open released by NNT
MCGA-Port_Marine_Guide_to_Good_Practice_NEW-links.pdf
Download [5 KB]
Interim Guidance on Maritime Security for Member States’ Competent Authorities - EMSA [2023, PDF]
Safety and health in ports - ILO [2005, PDF]
Cyber Security Code of Practice for Ships - Department for Transport, UK [2023, PDF]
Dangerous Goods in Harbour Areas Regulations (UK) - HSE [2016, PDF]
Guidance on Maritime Security for Member States’ Competent Authorities - EMSA [2022, PDF]
Pilot Transfer Operations - IMPA [2024, PDF]
Garbage Management Manual - ABS [2012, PDF]
EMSA’s Best Practice Guidance on the Inventory of Hazardous Materials - EMSA [2016, PDF]
The Selection and Testing of Valves for LPG Applications - SIGTTO [2012, PDF]
The time now is: Today 14:20
