metallicoholic1712@gmail. ®   01-May-2021 15:15
Hello everyone,
I am presently on board and have access to Witherby Seamanship Ebook Reader with plenty of licenced marine books.
Any one have any idea how to extract from the software and have a readable pdf?
I dont want to upload huge files with image scans.
If anyone has a solution please PM or reply here so that i can start uploading all kinds of genuine uptodate paid stuff which is not usually available elsewhere.
Thanks in advance.
sahilvijay   01-May-2021 15:37
metallicoholic1712@gmail., Yes, you can locate pdf files in the C drive under witherby folder in program files section of installed location. Moreover those pdf are highly encrypted. This will solve your purpose of extracting files ie pdf but will not serve purpose of unlocking them. Hope that helps.
SMA   01-May-2021 17:03
Try click on the print icon and then choose to save as pdf. if copyright allows printout, u will get a book as readable pdf
zuburki   03-May-2021 12:13
metallicoholic1712@gmail., the software has the passwords or is using md5 to check verification of the license file you use for the books... Can you confirm the version of the software is it "Witherby Library 5.x"?
gillnumil   05-Feb-2022 15:36
metallicoholic1712@gmail., Not possible to save any pdf from Witherby's or Admiralty for that matter.
The only solution is save each page as a screenshot and finally combine all as a pdf.
But quality of the saved snapshot is not as good as in the reader software.
Good enough for making references and referring a few points from the book. Till something better comes along.
But definitely not worth reading the whole book in that format.
twicer   05-Feb-2022 15:47
gillnumil, better to use any "pdf printer", means while printing use "save as pdf". in case the Reader limited for pages to print just move a pc's date ahead for day
gillnumil   05-Feb-2022 15:59
twicer, tried that with Adobe pdf and Cute Pdf ..but dosent work with both the softwares - Admiralty and Witherby are built to avoid this so that a pdf cannot be created.
The only way was to take screenshot. but for that too they have made sure that the quality detoriates and not crystal clear like in a ebook. distorts more upon zooming.
twicer   05-Feb-2022 16:23
this is a mad, in my case used virtual os for the Reader and printing "as pdf" on real pc (Mac). all gone fine. give me a serial then wl print for you Смех
https://www.clarksons.net
Problem with ratio & seeding on your tracker
ECDIS Procedures Guide 2019 and ECDIS Passage Planning and Watchkeeping 2019
Witherby Connect: User Guide - Witherby [2023, PDF]
Как сделать скриншот? / How to create screenshot?
Basic marine engineering
DNV-ST-N001 2023-12
An Introduction to Marine Engineering, for Cadets and Deck Officers - B. Sanchez [2017, EPUB]
Looking for ADMIRALTY e-NP Reader software.
Whiterby seamanship Navbasics
  • Topic closed
The time now is: Today 11:56
