ezhilz ®   18-Sep-2018 20:48
Marine Steam Boilers
Year: 1980
Author: James H. Milton and Roy M. Leach
Genre: Technical book
Publisher: BUTTERWORTHS LONDON
Edition: Fourth
Pages count: 597
Description: The marine engineer today is faced with a subject of immense scope due to the wide variety of types of propelling machinery, both steam and oil. High speed passenger liners, for which steam power remained supreme for over sixty years, are no longer commonplace and the present day role of steam for propulsion is in vessels of very high power such as large tankers and fast container ships. The choice of steam for propulsion of tankers is favorably influenced, to some extent, by the fact that steam is additionally a convenient means of cargo heating and pumping. Nowadays, very few oil-engines vessels are built without a steam boiler of some description being included in the machinery installation and, in the case of oil-engines tankers, it is quite usual to find a pair of large auxiliary water tube boilers — often of double evaporation type. The increase in the number of shipbuilding nations in recent years has brought about a similar increase in the types of main and auxiliary boilers available to the shipbuilder, and a corresponding need for marine engineers to keep abreast of all such developments.
1.Historical development of the marine boiler
2.Theoretical development of the marine boiler
3.Various types of boilers
Marine Steam Boilers.pdf
Download [16 KB]
gillnumil   19-Sep-2018 14:01
ezhilz,
After uploading kindly download back your own torrent to start seeding. Currently Seeder not seen.
gillnumil   19-Sep-2018 14:37
ezhilz, please keep seeding and do not remove from your system. If you have bandwidth issue you can go to options in utorrent and minimize upload rate.
Operation of Machinery in Ships: Steam Turbine, Boilers and Auxiliary Plant - A. NORRIS, C.Eng.,…
Marine Low Speed Diesel Engines (MEP Series: Volume 2, Part 17) - Dr. Dennis Griffiths [2000, PDF]
Marine Machinery - Liviu Constantin Stan (Nautica) [2010, PDF]
Marine Engineering Diploma [2023, MP4]
CD-44 Manuals: LNG, LPG, Tanker, Passenger, Container Ships - ermo1956 [2022, PDF]
REEDS Vol 16: Electrical Power Systems for Marine Engineers - Gordon Boyd, Fred Taylor [2020, PDF]
Specificity and designing of multi-hull ships and boats - Dubrovsky V. [2016, PDF]
Modern Marine Engineer Manual - Volume II - Alan Osbourne [1991, PDF]
Marine Auxiliary Machinery (7th Edition) - H. D. McGeorge [2018, PDF]
The time now is: Today 14:22
