sourabhharel96 ®   14-Apr-2021 10:56
The Theory and Practice of Controllable Pitch Propellers
Year: 1981
Author: COMMANDER E. R. MAY, R.N., C.Eng., F.I.Mar.E.
Genre: Reference book
Publisher: IMarEST
ISBN: 0 900976 62 4
Pages count: 30
Description: Controllable pitch propellers were first introduced in sailing craft with
auxiliary steam propulsion. The earliest auxiliary steamships frequently had
lifting propellers. Much ingenuity was bestowed on unshipping and shipping
propellers at sea, as an evolution. The phrase "up funnel, down screw" is
typical of those days. It was soon found that the difficulties of shipping and
unshipping a propeller at sea could be formidable. The objective was
reconsidered. The only purpose of having a removable propeller was to
reduce the induced drag when the ship was sailing. After some experience of
lifting propellers, it was felt that an adequate reduction in drag might be
achieved if the propeller blades could be feathered when sailing. To feather,
the propeller blades were turned into a position in which their drag would be
a minimum. The propellers concerned were nearly all two-bladed. They
were fitted with mechanisms-usually a system of rods and levers-the
ultimate function of which was to turn the blades on the pintIes to which they
were secured on the cast iron boss of the propeller. Those parts of the
mechanism which were outboard were permanently immersed in water. The
mechanism was of the simplest description and commonly lacked any
provision for lubrication.
MEP Vol. 2.13 CPP.pdf
Steering Gear - W. S. PAULIN, [1981, PDF]
Practical Ship Handling - Malcolm C. Armstrong [1994?, PDF]
Ship Propellers - S. V. Antonenko [2007, PDF]
The Wageningen Propeller Series - Kuiper G. [1992, PDF]
Prime Movers for Generation of Electricity- (A) Steam Turbines - A. NORRIS, C.Eng., F.I.Mar.E. [1981...
Application Of Automatic Machinery and Alarm Equipment’s In Ships - B. G. SMITH [1979, PDF]
Steam, Steel, and Torpedoes - The warship in the 19th Century - Lyon D. [1980, PDF]
Model Boats Volume 68 Number 812 - Graham Ashby (editor) [2018, PDF]
Medium Speed Engine Simulator v.2.2.0.44 [2001]
Hydrodynamic Propulsion and Its Optimization_ - J. A. Sparenberg [1995, PDF]
The time now is: Today 23:39
