twicer ®   26-Feb-2021 04:19
Victualling Digital Workbook [xls]
Year: 2019
Version: 4.00
Developer: Garrets
64-bit OS compatibility: yes
System Requirements: Windows or MacOS
Crack: Not needed
Description: The Garrets Workbook is an administration tool that assists you in giving an overview of your current stock situation.
Furthermore, it gives you an easier ordering tool with a product assortment that has been customized to your vessels needs and agreed spends.
Some of the benefits of the workbook include the following:
• Saves time on board
• Works as a tool for composing an order
• Works as a tool for stock, purchasing and manning monitoring and reporting
• Allows quicker closure on monthly stock validation
• Has more automatic processes (less mistake prone)
• Has a more user friendly interface
Readme
- definitely, it can and should be used privately, without sending orders or reports and etc.
- everything is easy to edit using all sheets and VBA (Alt+F11) passwords, read - wb_pass.txt
- when open 1st time your WORKBOOK (WB) YOU WILL BE PROMPTED TO ENTER IMO NUMBER then enter "9514666"
OR change the name of data file \Garrets\Do not open\9514666_Data.txt
- user manual included
Garrets
Download [16 KB]
Asset Management Operating System AMOS Business Suite 9.2. User Guide. - SpecTec [2012, PDF]
RS Digital Catalogue 2022 - RS Components Ltd. [2022, EXE]
RS CATALOG (ELECTRO,ELECTRONIC,AUTOMATION,TOOLS & OTHER EQUIPMENT) 2012 - RS [2012, PDF]
DigiTrace v.5.2 - Marine Press of Canada [2012]
Handbook for improving living and working conditions on board fishing vessels - ILO [2010, PDF]
Diploma in Ship Superintendency - Module 9 - Lloyds Maritime Academy [2015, PDF]
IMPA Marine Stores Guide v.1.1 4th Edition (Portable) [2004]
User’s Guide CoCoS EDS (Engine Diagnostics System) Version 1.70 - MAN Diesel [2008, PDF]
Subsea Processing System Advisory - ABS [2018, PDF]
The time now is: Today 20:34
