zxc ®   07-Oct-2012 19:52
User’s Guide CoCoS EDS (Engine Diagnostics System) Version 1.70
Year: 2008
Author: MAN Diesel
Genre: MANUAL
Publisher: MAN Diesel
Quality: OCR without errors
Number of pages: 160
Description: What is CoCoS EDS?
CoCoS EDS stands for: Computer Controlled Surveillance – Engine Diagnostics System.
It is one of two PC software applications of the CoCoS System. The other application is CoCoS Maintenance which is used to assist with the following:
  • Maintenance forecasting and planning
  • Spare part ordering and stock handling
  • Job execution, follow up and reporting
  • Spare part and maintenance instruction viewer
The CoCoS applications can be used for marine and stationary engines.
Similarly, CoCoS EDS is equally suitable for surveillance of a single engine or a group of engines making up an engine plant of any size. Continuous surveillance of the performance (operating state and behaviour) of an engine is an effective way of avoiding economic losses due to engine stoppages and expensive repairs.
CoCoS EDS provides such surveillance, keeping the operating personnel informed at all times of the engine condition with relevant data. Thus, it facilitates early intervention and preventive maintenance, so as to reduce the risk of costly engine stoppages and even breakdowns.
CoCoS EDS fulfi ls four primary engine surveillance tasks, which are always available to the user when using the program:
Data Logging,Monitoring,Diagnostics,Trend logging.
These are based on MAN Diesel‘s many years of experience with diesel engines and are especially developed to help chief engineers and maintenance personnel effectively maintain marine and stationary engines in optimal operating condition.
CoCoS EDS and CoCoS Maintenance can work alone or separately, along side one another on the same PC. Both are supplied with comprehensive data concerning your particular diesel engine plant and therefore are ready to assist you from the moment that you fi rst start using them. Together they offer a total solution for managing your entire diesel engine plant more effi ciently, saving both time and costs.
This User’s Guide applies to CoCoS EDS, Software Version 1.70
This User’s Guide applies to CoCoS EDS, Software Version 1.70. It provides an introduction to and an overview of the entire CoCoS EDS system for surveillance and diagnostics on two and four stroke diesel engines for marine propulsion and stationary power plants.
The guide sets out to provide ship and power plant engineers, as well as engine crew and offi cer supervisors with the knowledge essential to understanding the CoCoS EDS concept, structure and function, so that they can more quickly master the system when they begin using it.
Trademarks Windows, Windows XP and Windows Vista are trademarks of the Microsoft Corporation, U.S.A.Acrobat PDF Reader is a trademark of Adobe Systems Inc., U.S.A.
Conditions of Licence The supply, distribution and use of the CoCoS EDS and Engine Data, including the CoCoS System Documentation, are subject to your acceptance of the Standard Conditions of Licence which are supplied in the Software Package containing CoCos EDS and data media.
Welcome to CoCoS EDS, MAN Diesel‘s Computer Controlled Surveillance – Engine Diagnostics System.
CoCoS EDS is one of two PC software applications belonging to the CoCoS System. The other application is CoCoS Maintenance which is available as an option for planning and execution of all aspects of diesel engine maintenance.
CoCoS EDS provides optimum, cost-effective surveillance of diesel engines to ensure ideal running conditions and early forecasting of faults.
It facilitates both protective and predictive maintenance and is applicable for all MAN Diesel’s diesel engines, including auxiliary equipment.
These include two- and four-stroke marine and stationary engines, encompassing single, as well as multi engine plants of any size.
Before You Begin About this Guide
1.1 About this Guide
This User’s Guide is especially prepared to give you and other users the knowledge essential to understanding the concept, structure and function of CoCoS EDS, so that you can more quickly master the system when you begin using it.
The guide is structured to provide both brief and detailed information in order that you can quickly and easily obtain an overview of CoCoS EDS, as well as become familiar with the majority of its commands which you will fi nd of benefi t in your day-to-day work with your engine plant.
The guide includes the following chapters:
Chapter 1 Before You Begin: This is the chapter which you are now reading.
It provides brief details about the contents of this Guide and shall help you to get to know and use CoCoS EDS. In addition it contains a brief explanation of the system, including its applications and features.
Chapter 2 Exploring CoCoS EDS: Deals with basic operation of CoCoS EDS.
It explains what you need to know in order to start using the system on your PC.
Chapter 3 Measurements & Diagnoses: Explains how to use CoCoS EDS for manual and semi-automatic input of off-line measurements, including engine diagnoses on off-line measurements.
Chapter 4 System Administration & Tools: Explains how to set up CoCoS EDS for daily use, customise different views and parameters, as well as set up online data logging, etc.
Chapter 5 CoCoS EDS Concepts: Explains about the concepts and principles
behind CoCoS EDS so that you can more easily master using the system.
Chapter 6 Menus & Commands: Provides a simplifi ed overview of the commands in the menu system of CoCoS EDS.
Appendix Gives brief information on system requirements for using CoCoS EDS on
your PC, keyboard short-cuts and how to obtain technical assistance.
Glossary Explains many of the terms and abbreviations used throughout this Guide.
Table of Contents
C – 1
Table of Contents
Table of Contents ............................................................................ C – 1
1 Before You Begin ............................................................. 1 – 1
1.1 About this Guide ............................................................... 1 – 5
1.2 What is CoCoS EDS? ........................................................ 1 – 7
1.3 Primary Applications ......................................................... 1 – 9
1.3.1 Data Logging ..................................................................... 1 – 9
1.3.2 Monitoring ......................................................................... 1 – 9
1.3.3 Diagnosis ........................................................................... 1 – 10
1.3.4 Trend .................................................................................. 1 – 11
1.4 Additional Features ............................................................ 1 – 13
1.4.1 User Related Features ....................................................... 1 – 13
1.4.2 Data Related Features ....................................................... 1 – 14
1.5 Product Support and Training ........................................... 1 – 15
2 Exploring CoCoS EDS ....................................................... 2 – 1
2.1 Starting CoCoS EDS .......................................................... 2 – 5
2.2 The Main Window .............................................................. 2 – 7
2.2.1 Engine Views ..................................................................... 2 – 8
2.2.2 Mouse & Keyboard Operation ........................................... 2 – 11
2.3 Monitoring Views ............................................................... 2 – 13
2.3.1 Engine Overview ................................................................ 2 – 13
2.3.2 Standard Report ................................................................ 2 – 13
2.3.3 Reports .............................................................................. 2 – 14
2.3.4 Line Recorder .................................................................... 2 – 14
2.3.5 Bar Charts ......................................................................... 2 – 16
2.3.6 Characteristic Maps .......................................................... 2 – 18
2.3.7 Load Diagram .................................................................... 2 – 19
2.3.8 Performance Curves & Tables ........................................... 2 – 19
2.4 Trend Views ....................................................................... 2 – 23
2.4.1 Time Plots .......................................................................... 2 – 23
2.4.2 X-Y Plots ............................................................................ 2 – 25
3 Measurements & Diagnoses ........................................... 3 – 1
3.1 Measurements Menu ......................................................... 3 – 5
3.1.1 Read Pressure Curves ....................................................... 3 – 5
3.1.2 Manual Input ...................................................................... 3 – 7
3.1.3 Diagnostics ........................................................................ 3 – 9
3.1.4 Measurements ................................................................... 3 – 9
3.1.5 Import/Export Measurements ............................................ 3 – 10
3.1.6 Store Measurement ........................................................... 3 – 11
MAN Diesel
CoCoS EDS User’s Guide – Version 1.70 Table of Contents C – 2
3.2 Diagnosis Menu ................................................................. 3 – 13
3.3 System Log ........................................................................ 3 – 15
3.4 Line Recorder Database .................................................... 3 – 17
4 System Administration & Tools ...................................... 4 – 1
4.1 Logging on & Changing Passwords .................................. 4 – 5
4.2 Customising Views ............................................................ 4 – 7
4.2.1 Reports .............................................................................. 4 – 7
4.2.2 Display Groups .................................................................. 4 – 7
4.2.3 Unit Systems ...................................................................... 4 – 8
4.3 Setting Up Operation ......................................................... 4 – 11
4.3.1 Global Settings .................................................................. 4 – 11
4.3.2 Static Values ...................................................................... 4 – 12
4.3.3 Operating Hours ................................................................ 4 – 13
4.3.4 Line Recorder Database .................................................... 4 – 13
4.3.5 Line Recorder – Data Logging ........................................... 4 – 14
4.3.6 Calibration ......................................................................... 4 – 15
4.4 Restructuring Database ..................................................... 4 – 17
4.5 Backing up and Restoring Data ......................................... 4 – 19
4.5.1 Backing up Data ................................................................ 4 – 19
4.5.2 Restore Autobackup ......................................................... 4 – 20
4.6 Exporting Data of Trends and Measurements ................... 4 – 21
4.6.1 Measurements and File Location ....................................... 4 – 21
4.6.2 Trends ................................................................................ 4 – 22
4.6.3 Subset of Operating Values ............................................... 4 – 22
4.6.4 Unit and Rounding ............................................................. 4 – 23
4.6.5 Starting the Export Process ............................................... 4 – 23
5 CoCoS EDS Concepts ....................................................... 5 – 1
5.1 The CoCoS EDS Environment ........................................... 5 – 5
5.1.1 On Board Ships & At Power Plants ................................... 5 – 5
5.1.2 At the Main Offi ce .............................................................. 5 – 6
5.1.3 On-line Operation .............................................................. 5 – 6
5.1.4 Off-line Operation .............................................................. 5 – 7
5.2 Data Flow in CoCoS EDS .................................................. 5 – 9
5.2.1 Data Logging ..................................................................... 5 – 9
5.2.2 Filtering of Operating Data ................................................ 5 – 10
5.2.3 Operating Values & Status Checks .................................... 5 – 10
5.2.4 Manual Input & Manual Operating Values .......................... 5 – 11
5.2.5 Nominal Values & Characteristic Maps .............................. 5 – 12
5.2.6 Monitoring .......................................................................... 5 – 12
5.2.7 Evaluation & Diagnosis ...................................................... 5 – 13
5.2.8 Diagnoses – Open, New, Changed, Closed, etc. .............. 5 – 14
5.2.9 Trend .................................................................................. 5 – 16
5.2.10 Views – On-line & Off-line .................................................. 5 – 17
MAN Diesel
Table of Contents
C – 3
6 Menus & Commands ........................................................ 6 – 1
6.1 System Menu ..................................................................... 6 – 5
6.2 Edit Menu ........................................................................... 6 – 7
6.3 View Menu ......................................................................... 6 – 9
6.4 Reports Menu .................................................................... 6 – 11
6.5 Monitoring Menu ............................................................... 6 – 13
6.6 Diagnosis Menu ................................................................. 6 – 15
6.7 Trend Menu ........................................................................ 6 – 17
6.8 Measurements Menu ......................................................... 6 – 19
6.9 Tools Menu ........................................................................ 6 – 21
6.10 Windows Menu .................................................................. 6 – 23
6.11 Help Menu ......................................................................... 6 – 25
Appendix .......................................................................................... A – 1
A.1 CoCoS EDS Requirements ................................................ A – 3
A.2 Software Installation .......................................................... A – 3
A.3 Keyboard Functions & Shortcuts ....................................... A – 3
A.4 Technical Assistance .......................................................... A – 6
Glossary ........................................................................................... G – 1
Glossary of Terms ............................................................................. G – 3
Index ................................................................................................. I – 1
MAN Diesel
EDS
User’s Guide PMI System (On-line) Pressure Analyser Version 2.0 - MAN B&W Diesel A/S [2001, PDF]
JRC JAN-701B/JAN-901B (Instruction Manual) - Japan Radio Company [2012, PDF]
DataChief C20 - Alarm and monitoring system with process control and power management (Instruction…
Maris ECDIS900 Operator Manual - Navico Holding AS [2017, PDF]
International Guidelines for the Safe Operation of Dynamically Positioned Offshore Supply Vessels -…
The time now is: Today 15:05
