NNT ®   12-Mar-2015 20:30
Intact Stability
Year: 2010
Author: Colin S. Moore
Genre: Principles of Naval Architecture Series
Publisher: The Society of Naval Architects and Marine Engineers
ISBN: 978-0-939773-74-9
Pages count: 110
Description: The concept of dynamic stability is introduced, starting from the ship’s response to an impulsive heeling moment. The effects of waves on resistance to capsize are discussed noting that, in some cases, the wave effect may result in diminished stability and dangerous dynamic effects.
Problems encountered in ships of special type and size that have been developed in recent years, many of which - by reason of size, configuration or lack of a history of design experience - require a design approach based on first principles, receive special attention. Modern developments in classification society strength standards and modern rule developments are covered, including Common Structural Rules for tankers and bulk carriers.
There are sections on the special stability problems of craft that differ in geometry or function from traditional seagoing ships including multihulls, submarines and oil drilling and production platforms. The final section treats the stability of high performance craft such as SWATH, planing boats, hydrofoils and others where dynamic as well as static effects associated with the vessel’s speed and manner of operation must be considered in order to insure adequate stability.
Principles of Naval Architecture Series - Intact Stability-(SNAME)(2010)
Download [6 KB]
rones   25-Mar-2018 23:12
don't you have? : Principles of Naval Architecture Series: Propulsion, Principles of Naval Architecture Series: Ship Resistance & Flow and Principles of Naval Architecture Series: Vibration 2010.
Intact Stability - Principles of Naval Architecture (PNA) Series - Colin S. Moore [2010, PDF]
The Principles of Naval Architecture Series--Strength of Ships and Ocean Structures - Prof. Alaa…
Ship Resistance and Flow - Lars Larsson & Hoyte C. Raven [2010, PDF]
Air Lubricated and Air Cavity Ships: Development, Design, and Application - Pavlov G.A., Liang Y.,…
Principles Naval Architecture - Vibration - William S. Vorus [2010, PDF]
Statics and Dynamics of the Ship - V. Semyonov-Tyan-Shansky [1966, PDF]
Wing-in-ground effect vehicles - Rozhdestvensky K.V. [2006, PDF]
Muckle’s Naval Architecture - By W. Muckle and D A Taylor [2013, PDF]
List of ABS Notations and Symbols [2025, PDF]
Specificity and designing of multi-hull ships and boats - Dubrovsky V. [2016, PDF]
The time now is: Today 14:16
