twicer ®   05-Feb-2021 00:30
Industry Standard on In-water Cleaning with Capture
Year: 2021
Author: ICS
Publisher: ICS and BIMCO
Pages count: 62
Description: This industry standard helps to ensure that the in-water cleaning of a ship’s hull, and niche areas including the propeller, can be carried out safely, efficiently and in an environmentally sustainable way.
The primary users are shipowners, who are responsible for managing biofouling on the ship’s hull, propeller and niche areas, and approved cleaning companies (i.e. in accordance with the standard’s requirements for approval of in-water cleaning companies). The industry standard can also be used by ports and other authorities for making decisions regarding permits, etc. Finally, the industry standard provides a possibility to improve the level of communication between shipowners and AFS manufacturers.
This is one of two separate documents that outline performance-based requirements for in-water cleaning of a ship’s hull, propeller and niche areas with the capture of the materials that are removed during the process.
Industry Standard for in-water Cleaning.pdf
Download [4 KB]
Approval Procedure for in-water Cleaning Companies - ICS [2021, PDF]
Guide to New Zealand’s Biofouling and Ballast Water Requirements - INTERTANKO [2019, PDF]
Equivalent standards for the construction of Artic Class Ship TP 12660 - N/A [1995, PDF]
Port State Control Safeguarding Responsible and Sustainable Shipping, Annual Report 2017 - Paris MoU...
Model Ballast Water Management Plan - Lloyd’s Register [2020, docx]
Faith and Burial for Seafarers - Internatinoal Chamber of Shipping (ICS) [2022, PDF]
Global Maritime Distress and Safety System: GMDSS - Norwegian Shipowner’s Association [19XX, PDF]
Shipping Industrial Structure - Ladi Utleylone [2015, PDF]
Common Guidelines for LNG Bunkering Operations at Spanish Ports - Lloyd’s Register [2021, PDF]
Guidelines on the medical examinations of seafarers - ILO [2013, PDF]
The time now is: Today 03:52
