twicer ®   04-Feb-2021 16:41
Approval Procedure for in-water Cleaning Companies
Year: 2021
Author: ICS
Publisher: ICS and BIMCO
Pages count: 30
Description: This approval procedure sets minimum requirements for approval of in-water cleaning companies that remove and capture macrofouling organisms (i.e., visible to the human eye, as defined in IMO Guidelines 2011) which have colonised the immersed surfaces of ships.
This is one of two separate documents that outline performance-based requirements for in-water cleaning of a ship’s hull, propeller and niche areas with the capture of the materials that are removed during the process
Approval Procedure for in-water Cleaning ICS 2021.pdf
Industry Standard on In-water Cleaning with Capture - ICS [2021, PDF]
Guidelines for Cyber Resilience of Ships - ClassNK [2024, PDF]
Calculation of marine propellers, DNVGL-CG-0039 - DNV GL [2015, PDF]
Inventory of Hazardous Material Maintenance Manual - Synergy Group [2020, PDF]
Guidelines for Type Approval of Products for Marine Use for EU Mutual Recognition - ClassNK [2022,…
Guide for Exhaust Emission Abatement - ABS [2018, PDF]
Rules for Technical Supervision during Construction of Ships and Manufacture of Materials and…
Adhesives in marine engineering - Jan R. Weitzenbock [2012, PDF]
Iridium GMDSS Design & Installation Guidelines - Iridium Satellite LLC [2019, PDF]
The time now is: Today 15:12
