Dimi4 ®   25-Sep-2012 20:25
Norcontrol Neptune Desktop Simulator - MC90-IV
Version: 1.2
Platform: Win 32
System Requirements: стандартные
Crack: Присутствует
Description: Norcontrol Neptune Desktop Simulator - MC90-IV
ещё один симулятор
Additional info: Keyboard Commands
The following contains a list of keyboard commands to control and monitor the simulation.
F1 Run simulation
F2 Freeze simulation
F3 Stop, end simulation
F4 Snapshot
F5 Operating condition
F6 Scenario
F7 Recall picture
F8 Alarm log
F9 Malfunction page directory
F10 Variable page directory
F11 Alarm page directory
F12 Alarm silence
Home Picture directory
Page Down Next picture
Page Up Previous picture
Shift + F4 Replay/Snapshot dir.
Shift + F6 Initial condition
Shift + F7 Mark picture
Shift + F8 Alarm log acknowledge
Alt + F12 Toggle window decorations
Shift + Home Picture number (mdxx)
All rights reserved
Simulator ME_Norcontrol Neptune-MC90-IV
zooki   12-Mar-2013 02:20
Greetings from croatia!!
I would be really grateful to my Russian colleagues if somebody could help me with this simulator.
I have a problem running it on my Windows 7 64bit Ultimate OS.
It doesn't want to start, an error pops up saying:
"RTM initialization failed for process "rtm_1"
Cause: missing entries in services database
Action: check your services database as described in the SWBus User's Guide
Optionnaly run the program
$BUSPATH/examples/$arch/testServicesDb
to pinpoint the problem with your services database "
I tried to google SWBus, it looks like that is some component for running the simulator.. and i dont have it.. or there is some another problem that i'm not aware of.. So pls help me if someone managed to solve this problem!
Thx in advance and i wish calm seas to all russian navigators world wide!
6
narugpopeye   07-May-2013 00:37
Ребята,куда нажать чтоб скачать етот симулатор?
Dimi4 ®   07-May-2013 07:26
Привет!
1_ install in the C:/ hard drive the program normally the installation is lauched alone or click
2_ copy the crack (simulator.exe) in the folder C:\Program Files\Norcontrol\Neptune\Bin
3_ start the program normally and click on OK when it ask you for the code
1) Установите програму на диск С:/, как любую обычную програму,соглашаясь со всеми пунктами установщика(или попросту-жми Next или Yes в каждом окне инсталятора)
2) Скопируйте "кряк" (файл simulator.exe из папки "crack without key")в папку С:/ProgramFiles/Norcontrol/Neptun/Bin
3) Для запуска програмы - 2клика на ярлыке на Рабочем столе
Удачи!
Guest   07-May-2013 12:04
Spasibo, za pomosh. Da ja ponjal instrykciu, no pri ystanovki rygaetsa chto nexvataet chegoto, stringa... Rebjata esli ni len poprobyite shag za shagom napisat. Ochen nygno,cherez nedelu test sdavat, bilo bi tak ydobno doma na simulatore poprobovat.
narugpopeye   07-May-2013 12:19
Dimi4-y tebja na kakoi versii Windi32 ili 64? Voobshe on vrode zapyskaetsa( no rpi ystanovki rygalsa na string kakoi to) no net bibliotek, i ih ne vibrat toest esli dage zapysti ExerciseWraper to tam ne vibrat scenariiy,esli mogesh prover kak ystanavlivat.
Ja tak ponimau chto iz-za togo chto pri ystanovki on rygaetsa na string, iz za etogo nerabotaet. Moget tam pri ystanovki user name ,i komy licenzija prinadlegit nado pravilno propisat?
narugpopeye   07-May-2013 12:23
vot chto pishet:
D|11:00:31|0.0000|SimMgr|Initialize: plant='C:\Program Files (x86)\Norcontrol\Neptune\MC90-IV'|||
E|11:00:31|0.0000|SimMgr|Unknown module in command line argument: 'P3Com:maximized'|||
E|11:00:31|0.0000|SimMgr|Cannot locate UnitScheduler|Can not continue startup||
E|11:00:31|0.0000|Neptune|Could not get IMessageLogger interface|Unable to update process log|Correct the configuration|
D|11:00:31|0.0000|Neptune|Started: C:\Program Files (x86)\Norcontrol\Neptune\Bin\Ess.exe ""|||
D|11:00:43|0.0000|SimMgr|Shutdown|||
Dimi4 ®   13-May-2013 02:24
Привет,
уменя Windows XP sp3 32bit, установилось всё с полпинка
Наверно эта проблема связана с установкой програмы на 64х-битную систему...
Попробуйте перед установкой в свойствах файла Setup.exe на вкладке совместимость установить совместимость с WindowsXP sp3 и запуск от имени и с правами администратора,
А после установки тоже самое проделайте с файлом С:/ProgramFiles/Norcontrol/Neptun/Bin/simulator.exe
Ещё,при запуске симулятора выскакивает несколько окон:
1) Environment sound System
2)Process Display Directory MC90-IV
3)Process Log
Я так понял, что 1 и 3 лучше не закрывать а только сворачивать
quietmerch64   23-Oct-2013 18:53
I Managed to get the simulator installed, and have somehow stopped the errors from SwBus (rtm_1 errors). However I am getting an error which says "Missing argument: -p <plant path>. Any information would be greatly helpful!
Astart   07-Nov-2013 23:24
what system do you use?(windows)
OLGERT11   15-Nov-2013 08:15
Не работает. Специально нашел ноут с Win XP (32) SP3. Всю установку делаю , как рекомендовано, но он зараза даже код не спрашивает - запускается сразу и в режиме Freeze. То есть всё заморожено. При попытке запустить F1 - пишет, ЗАГРУЗИТЕ ПЕРВОНАЧАЛЬНЫЕ ПАРАМЕТРЫ. То есть окно запроса на лицензионный ключ даже не появляется. Под Win 7 (64) не пускается ни в какую - указывай, не указывай совместимость. Заточен только под 32 битные машины, думаю.То есть очень подозреваю, что будет работать или нет зависит от древности Винды. Вот хоть Win 2000 ставь теперь. Может под ней пойдёт. Причем этот симулятор скачал из двух разных источников - проблема осталась.
Soarer   15-Nov-2013 08:32
Так загрузите. Весело
Я тоже сначала не понял. Сейчас под рукой программы нет, ищите и обрящете - заработает. То ли в Хелпе было, то ли так натыкал.
Scenarios for Kongsberg Norcontrol Neptune Simulator - MC90-V v.for version 2.3 and 2.5 - Kongsberg…
Kongsberg Neptune Engine Room Simulator - MC90-V v.2.5.1 [2013]
IMO Model Course 6.10 - IMO [2012, PDF]
Kongsberg Norcontrol Neptune Simulator BigView3 MC90-V v.2.4.0.0259 - Kongsberg [2012]
Instruction manual for reefer container monitoring system - York Marine [20xx, PDF]
Medium Speed Engine Simulator v.2.2.0.44 [2001]
User’s Guide PMI System (On-line) Pressure Analyser Version 2.0 - MAN B&W Diesel A/S [2001, PDF]
Neptune Instructor System v.2.4.0.0258 - Kongsberg [2012]
Furuno Operator’s Manual Live Player V5, Model VR-7030 - Furuno [2014, PDF]
The time now is: Today 14:13
