NNT ®   02-Mar-2015 08:36
Ruddler Propeller and Hull Interaction
Year: 2000
Author: Claus D. Simonsen
Publisher: Technical University of Denmark. Department of Naval Architecture and Offshore Engineering, ISH
ISBN: 8789502272
Pages count: 236
Description: The flow field behind a ship in motion is disturbed by pressure and velocity fluctuations induced from the hull. Consequently, a propeller working behind the ship experiences a highly inhomogeneous inflow. This causes a varying load on the propeller blade during one revolution, resulting in a local pressure drop around the blade.
Depending on the operation conditions, e.g.,submergence of the propeller shaft or rotational speed, the pressure sags below vapour pressure and cavitation, i.e.,vapour pockets in the liquid, can be observed at the propeller. When again entering high pressure regions, the cavities collapse extremely rapidly and may cause noise and vibration, transferred to the ship‟s hull, and causing erosion on the propeller or the rudder.
Download [10 KB]
Rudder, Propeller and Hull Interaction by Rans - C. Simonsen [2000, PDF]
Mechanics of Ship Grounding - Bo Cerup Simonsen [1997, PDF]
Marine Propellers and Propulsion - J. S. Carlton [2019, PDF]
Practical Design of Ships and Other Floating Structures - Volume 1 - You-Sheng Wu, Guo-Jun Zhou,…
Hydrodynamics of Ship Propellers - Breslin J.P., Andersen P. [1996, PDF]
SHIP RESISTANCE AND PROPULSION Second Edition - Anthony F. Molland, Stephen R. Turnock, Dominic A.
Probabilistic Theory of Ship Dynamics - R. E. D. Bishop, W. G. Price [1974, PDF]
Numerical Predictions of Global and Local Ice Loads on Ships - Biao Su [2011, PDF]
Marine Propellers and Propulsion Third Edition - J S Carlton FREng [2012, PDF]
Centrifugal Pumps - Johann Friedrich Gülich [2014, PDF]
The time now is: Today 18:35
