Ferreirolo ®   14-Sep-2020 17:56
Guidance Notes on Ergonomic Design of Navigation Bridges
Year: 2003
Author: ABS
Publisher: ABS
Pages count: 116
Description: The ABS Guide for Bridge Design and Navigational Equipment/Systems presents requirements that “are applicable to vessels possessing SOLAS certificates and having the bridge so designed and equipped as to enhance the safety and efficiency of navigation.”
That Guide also recommends that the design of bridges is to be based on sound ergonomic principles. To support the bridge design and engineering community in promulgating these principles, these ABS Guidance Notes for the Ergonomic Design of Navigation Bridges have been developed.
These Guidance Notes for the Ergonomic Design of Navigation Bridges provide vessel designers with the ergonomic principles and data appropriate to the design of navigation bridges; and in doing so serve to supplement and support the ABS Guide for Bridge Design and Navigational Equipment/Systems. Ergonomic design guidance herein applies only to navigation bridges and associated equipment.
These Guidance Notes do not provide more generally applicable detailed ergonomic design guidance or data, such as control dimensions, environmental limits or human anthropometry. Those data can be found in the ABS Guidance Notes on the Application of Ergonomics to Marine Systems.
Extensive reference is also made to the ABS Guide for Crew Habitability on Ships and the ABS Guide for Crew Habitability on Offshore Installations. These documents present guidance related to the design of the accommodations and the ambient environment of a vessel’s bridge such as human whole body vibration, noise, indoor climate and lighting.
Ergonomic_Design_of_Navigation_Bridges.pdf
Download [614 B]
Guide for Bridge Design and Navigational Equipment - ABS [2022, PDF]
Guide for Bridge Design and Navigational Equipment/Systems - ABS [2019, PDF]
Guide for Bridge Design and Navigational Equipment and Systems - ABS [2022, PDF]
Guide for Ergonomic Container Lashing - ABS [2021, PDF]
Guidelines for Ships Using Alternative Fuels - ClassNK [2024, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl / Ethyl Alcohol / LPG / Ammonia) - ClassNK…
Guide for Bridge Design and Navigational Equipment and Systems [2024, PDF]
Guidance Notes on onboard Noise Analysis - ABS [2019, PDF]
Guidelines for the Prevention of Human Error Aboard Ships - ClassNK [201’, PDF]
Practices in Pilotage – Past, Present and Future - SIA Fin­land [20xx, PDF]
The time now is: Today 14:13
