SerTan ®   11-Jul-2020 05:04
MACS3 Training Course for Container Vessels
Year: 2020
Version: v.1.1.29.84
Developer: NAVIS
System Requirements:
Crack: Not needed
Description: The MACS3 Training Course for Container Vessels is designed for:
- students at maritime academies working on a certificate as a Navigational Watchkeeping Officer or higher
- experienced mariners and other persons with responsibilities in cargo operations.
The aim of this course is to provide training for using the loading computer system MACS3 for Container Vessels.
The following competencies will be gained and evaluated:
· Stability and strength
· Cargo handling
· Cargo stowage
· Cargo lashing
· Dangerous goods.
It is assumed that those who enter this course are familiar with cargo operations on container vessels and have knowledge of stability theory and longitudinal strength calculations for vessels. Participants should also be familiar with standard computer handling and software interfaces.
Upon successful completion of the course you will have an overview of the range of functions in the loading computer system MACS3 and be able to handle typical loading conditions and judge them with respect to safety-relevant aspects like stability and stress situation of the vessel, pre-plan ballast operations, produce loading and discharge, reefer and dangerous goods (DG) lists for cargo watch, produce all required reports on stability and strength, produce all required cargo related reports, receive necessary information on dangerous goods in case of emergency, customize the user interface of the system to suit your needs, use the user manual to go in depth for special functions.
Additional info: This course requires 16 hours of training time.
After familiarization with the course you will immediately install the necessary MACS3 software on your PC to be able to conduct all exercises and the evaluation. After that you will be guided through the basic modules and the general understanding of the user interface. Next, you will learn about how- MACS3 works in practice: your vessel by corresponding and exchanging data with planners and terminals. Chapter 8 “Condition Check” involves comprehensive study about the regulatory stability and stowage checks offered by MACS3 and are required before every voyage. Chapters 9-11 will teach you how to prepare ballast water operations, loading plans and various reports for your crew and charterer. By this time you will have become a professional MACS3 user and will be able to adjust and configure the user interface individually. Chapter 13 will deal with the “Test Conditions” based on your vessels class rules. Finally security aspects, failures and help options are discussed.
Instead of a user manual or help files, this course is story-based, meaning it will present you with typical tasks you will have to handle on board. This is done step by step, chapter by chapter.
The way you receive information in this course varies between text, images, short explanatory videos, and the fully functional MACS3 container ship training software.
Please note: Theoretical basics like stability calculation principles, theory of shear forces and bending moments, and lashing forces will not be covered in this course.
There are some test answers included in this upload.
MACS5 Training
Download [37 KB]
maksymms   16-Jul-2021 16:10
Спасибо большое за ваш труд!!!
pdf файлы открываются и читаются на ура, а вот программу не удается запустить. Не хочет она/он (Макс) грузить информацию о судне. Подскажите пожалуйста алгоритм установки программы
установщик ругается что нет данного файла, хотя он в папке есть (microsoft.extensions.dependencyinjection.abstractions.dll)
guled   08-Nov-2023 17:13
Good program, but I can not find the full layout. Could you please upload the layout?
b47b56   13-Jan-2024 13:26
Ищу профили на Macs3.
Просьба у кого есть возможность скиньте, пожалуйста, .shp/.dat файлы на почту [email protected]
В целом интересны любые проекты - контейнеровозы\MPP
очень ищу следующие:
- DaeSun 1000 - любой год (Glevin, Pacanda, Okee Aurelia, Lantau Bay, Wes Sina и т.д.)
- Sietas 151 - (Ragna, Victoria, Dornbusch, BF Cartagena и т.д.)
- CW700 (Cassens Werf) с/без кранов - (Pafilia, Sing, Atlantic Bridge, Atlantic Pioneer, Pacific Monaco).
slava_niki   07-Jan-2025 08:12
В описании написано курс рассчитан на 16 часов. Раздачу скачал, не пойму откуда там возьмется 16 часов? Видео с десяток другой длительностью по минуте и пдф файлы по 3-4 страницы.
Подскажите пожалуйста откуда там расчет длительности курсы на 16 часов? или может каких то файлов не хватает в раздаче?
Спасибо.
SVIATFONE   20-Mar-2025 05:33
У кого нибудь получилось загрузить файл другого судна?
Пробую ,постоянно выдает HARDLOCK error
Lacon   28-Mar-2025 12:32
SVIATFONE, На сколько я разбираюсь, если вы подгружает файл информации о судне, то именно он содержит информацию по ключу. Я взламывал на судне кряком именно этот файл и при подключённом ключе. Позже, уже дома, всё ставилось без проблем с заменой файла на взломанный. Так что, по моему, подгрузить можно только заранее взломанный файл.
YuryKomar   29-Jul-2025 11:49
SVIATFONE, Для этого, наиболее быстрый и действенный способ - внести некоторые правки в сам файл профиля судна, таким образом программа молча запускается. У новых профилей существует еще и маркер, указывающий на то, что профиль был выпущен без USB хардлока, но с цифровой лицензией, и просто отвязать от хардлока будет недостаточно, нужно так же затереть и этот маркер, чтоб обмануть программу.
Если сильно нужно, могу с этим помочь, так же могу обновить версию IMDG модуля на самую свежу, могу активировать Planning Mode и режим работы макса в STOWMAN.
Все выше перечисленное небесплатно.
sim vol   08-Jan-2026 14:04
Доброго времени суток. Предоставьте пожалуйста раздачу фалов. Торрент ничего не загружает. Спасибо!
Practical Loading of Merchant Vessels - Tom Abbenhues [2018, PDF]
ShipManager-88 v.4.0.3 (Loading/Unloading Program for 57000 DWT bulkcarrier) [2009]
LoadPlus - Loading computer application for 8300 DWT Oil/Chemical Tanker v.1.0.0 build 2347 - HANLA…
CargoMax for Livestock Carriers Demo v.2.1 - Herbert-ABS [2020]
Proficiency In Security Awarenesss For All Seafarers [2024, MP4]
Wartsila Transas Navi Sailor 4000 - Safebridge Type Specific Course 2022 [2022, MP4]
SimpleStow for Container Trial Version v.2.4.2.9 - Amt Marine [20??]
Transas ECDIS Workbook - Transas [2011, PDF]
BAPLIE Viewer v.2.1.2 - Capt. Dragan Milatovic [2005]
Cargo Loading and Securing Manual for Diamond 53 - Handymax Bulk Carrier - Chengxi Shipyard [2008,…
The time now is: Today 13:30
