zxc ®   10-Jan-2015 16:38
Hydrostatics and Stability by Dr. Hari V. Warrior
Year: 2012
Country: India
Genre: Educational
Playtime: 55min x 40 videos
Quality: CamRip
Format: MP4
Translation: Single voice
Starring: Dr. Hari V. Warrior
Lecture Details:
Hydrostatics and Stability by Dr. Hari V. Warrior, Department of Ocean Engineering & Naval Architecture, IIT Kharagpur. For more details on NPTEL visit www.nptel.iitm.ac.in
Course Description :
This is the first course for Naval Architecture students in 'Hydrostatics and Stability'. This course covers the basic principles of stability, starting from the Archimedes principle and going deeper into the conditions for stability of a vessel.
Study of metacentric height and radius gives an insight into Naval Architectural stability problem. A thorough study of the various weight shiftings which give rise to various forms of heeling are investigated. Conditions of free-surface effect and inclining experiment are studied.
This is followed by stability of the ship at larger angles of heel under various turning moments. The course then discusses about the various conditions of damaged stability, dry docking and launching calculations. A demonstration of the software 'SPAN' which performs these hydrostatic calculations will be demonstrated.
Contents: Hull form definition of ships and ocean structures; Deadweight, capacity and tonnage measurement; Numerical Integration, Hydrostatic calculations; Hydrostatic curves, Initial stability, free surface effects, stability at large angles; Intact and damaged stability computations; IMO stability criteria; Damaged stability and its calculation by lost buoyancy and added weight methods; Subdivision and floodable length calculations; Launching and dry docking calculations; Stability of fully submerged body; Stability of multibody systems; Pressure integration technique of computing hydrostatic and stability.
Video codec: QuickTime
Audio codec: MP3
Video: Bit rate : 335 Kbps Maximum bit rate : 2 259 Kbps Width : 450 pixels Height : 360 pixels Display aspect ratio : 5:4
Audio: Bit rate mode : Variable Bit rate : 96.0 Kbps Maximum bit rate : 139 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy
Hydrostatics and Stability by Dr. Hari V. Warrior  SILVER RELEASE!
Download [18 KB]
Ship Stability for Mates/Masters - Martin A. Rhodes [2013, PDF]
Diamond 53 - Handymax Bulk Carrier - Stability information manual - Carl Bro [2006, PDF]
Course Of Ship’s Stability And Trim - Faculty of Navigation [2010, PDF]
Naval Architecture for Marine Engineers: Volume 4 (Reed’s marine engineering series) - EA STOKOE…
MAN B&W - L+V 28/32 - Removal and Overhaul of cover, piston and liner [199x, MP4]
Sail Canada Basic Coastal Navigation Course Video, Session 2 - Wavelength Sailing School [2017, MP4]
Sail Canada Basic Coastal Navigation Course Video, Session 1 - Wavelength Sailing School [2017, MP4]
Merchant Ship Stability - A.R. Lester [1985, PDF]
GEA Westfalia Separator - Separation Technology [FLV]
Ship Stability OOW Training Program - Martin A. Rhodes [2009]
The time now is: Today 16:48
