thirdmate ®   18-Feb-2020 17:40
Chartco Passage Manager 6.0
Year: 2016
Version: 6.0
Developer: Chartco
64-bit OS compatibility: yes
Crack: Not needed
Description: PassageManager is ChartCo's flagship software, supplied to all subscribing vessels. Ease of installation and use has been paramount when designing this market leading application. This means no engineers are needed when commissioning the ChartCo service.PassageManager allows access to ChartCo's full range of services through an intuitive graphical interface providing 'at a glance' monitoring of all update statuses. With minimal 'clicks' paper and electronic product catalogues and outfits can be displayed together with any correction or permit status.PassageManager has been designed to facilitate the easy management of a data library which may consist of paper and electronic products and a bridge that uses ECDIS as well as more traditional methods of managing important navigational data.PassageManager now includes fully automated routeing and distance tables, allowing routes to be created almost instantaneously and transferred to and from most ECDIS systems as well as providing full integration with third party applications such as ADMIRALTY TotalTide.Using product, port, route, tidal, weather data and much more, PassageManager can create a comprehensive but fully customised passage plan within minutes. The passage plan is designed to meet bridge procedure guides, Standards of Training, Certification and Watchkeeping for Seafarers (STCW) and can be varied to meet the requirements of each vessel. The interface is designed around an easy-to-follow wizard ensuring that no part of the complex process may be missed. Following completion of the plan it can be saved, exported and recalled for quick modification or approval at any time.ChartCo also recognises that the increasing use of electronic data means that purchasing and updating activity is changing. Using PassageManager allows baskets of product requirements to be automatically generated from the route and sent to either the on-shore office for approval or direct to ChartCo. The supply of permits is then fully automated and takes only a few minutes.ChartCo's interest does not stop with data updates. Traditional methods of updating ENC data is through CDs or DVDs which means a ship can never be truly up-to-date. PassageManager allows ENC cells to be downloaded individually or as folios, making sure that a vessel has access to any new cell or new edition as soon as notification has been received whilst still minimising data costs
Additional info: Note - Yes, I am aware that VoloshykA has already posted this. But there are no seeders for the same and hence it cannot be downloaded. Hence am posting this again.
This software can be used for conversion of routes and thats the main reason am posting it here
Download [20 KB]
thirdmate ®   18-Feb-2020 17:50
Arcan,
It looks like you did not spend time trying to read the post before moving it or issuing a "Warning ". Can you please try to download from the original poster ? There are no seeders at all. There is no way anybody can download it . I had mentioned this very clearly that I am aware this is a duplicated post and the sole reason I am uploading it is because the earlier post does not have seeder.
So Arcan , next time try to read and understand the post before doing like this.
Arcan   18-Feb-2020 18:01
thirdmate, " Seeder not seen: 8 hours "
You can call seeders to give you a possibility to download this release and not to create new one. If no any one seeder replied you during 3 days - you can release once again needed release after moderator or administrator approved this.
thirdmate ®   18-Feb-2020 18:37
Arcan, " Seeder not seen : 8 hours " - For the past 4 days its been showing the same. I know, I have been checking upon it.
You may delete this post now. I wont be torrenting this release any case .
Passage Manager 6.0 + MetManager 7.0 - ChartCo [2016]
ADMIRALTY Digital Catalogue (ADC) v.1.8.8 - UKHO [2026]
Collection of ECDIS Routes , Version 1 - Tom Alex [2019, Other]
ChartBrowser v.2.4.6.8 - ChartWorld [2018]
NYK Standard for Navigation Using ECDIS - NYK Line [2014, PDF]
ADMIRALTY Digital Catalogue User Guide v2.6 - UKHO [2016, PDF]
SimpleStow for Container Trial Version v.2.4.2.9 - Amt Marine [20??]
Admiralty Digital Publications (ADP) v.24 - UKHO [2024]
The time now is: Today 17:01
