thirdmate ®   18-Feb-2020 19:10
Collection of ECDIS Routes , Version 1
Year: 2019
Author: Tom Alex
Format: Other
Quality: Unknown
Pages count: 289
Description: A few of us in this group would be Navigators. This is for them.
Almost all the ships in the world have ECDIS now. And best part of ECDIS is that we can use the same route over and over. And that means routes you make can be used by anyone. I work on a tanker and most of the time its fixed routes. Same routes somebody else would have gone many times. So lets make the work easier. I am sharing the routes I have made and few others I have collected from other navigators. I urge you to do the same. I shall keep updating this in regular intervals as I get more routes from others. Together we can make a Mega Collection of routes.
As always , check your routes thoroughly before using it. If you like to send me routes to be added to this collection , please PM me with link after uploading it
PS : The routes are made in format rtz. If you need to convert it , you may use the programme Chartco Passage Manager . I am sure there exists a few other similar program that can be used to convert the routes. Somebody has uploaded Passage Manager Program in this group , but there are no seeders and hence it cant be downloaded.
Various
ECDIS Routes
Download [20 KB]
Arcan   19-Feb-2020 11:20
thirdmate, Your P.S. does not apply to this release and carries unnecessary information. Please delete it, remain only re rtz format. Otherwise your entire release will go to trash.
Also, your release does not contain information - for what kind of ECDIS made your routes? I can say that your routes are absolutely useless except those kind of ECDIS you are used.
thirdmate ®   19-Feb-2020 13:49
Arcan, I disagree with you. The post script section informs people that Chartco Passage Manger is the software that can be used for converting the routes. However its not available in this group.
61384Otherwise your entire release will go to trash.
- Sure sir , as you wish
61384Also, your release does not contain information - for what kind of ECDIS made your routes? I can say that your routes are absolutely useless except those kind of ECDIS you are used.
- I dont know what Rank you are sir , but I am absolutely sure you have absolutely no clue of ECDIS working principles. The beauty of ECDIS is that routes made in rtz format can be used in any type approved ECDIS in the world. The whole point of sharing the routes is because I am sure somebody else can use it elsewhere in any ECDIS. 17 people have downloaded it already and never bothered to ask this stupid question. Thats because they know it can work and you dont
recycle   19-Feb-2020 14:59
thirdmate, depths, turn radius etc... differs between vessels so this concept is not optimal. Also, for example, please read the info @ https://www.routeinfo.no/faq
"Q:Limitations in size of vessel may vary along the route caused by regulation or depths?
A: In some routes depths or regulations imply that vessels of 150 m length and 9 m draught cannot use the entire route. Where there are regulations limiting the vessel size this can be found in the attached local regulations – See for example route to Tønsberg West (link), PEC regulation 105/125m max length, and VTS-regulations (Section 38 - 41). Where depths in part of a route cause limited vessel size without given in local regulations, this is included in the route name, like for example ‘7_5m_Mongstad_Steinsundet_Stad_In’ where a shallow area east of Olaskjaeret cause limitation in ship draught for the recommendation from NCA. "
virtual   19-Feb-2020 16:20
Thirdmate, 30 days ban for disrespectful behaviour. It's the best I can do for you.
thirdmate ®   19-Feb-2020 16:54
recycle, rtz is a common format among many ECDIS manufacturers. So yes this route can be used in most of the ECDIS. Your points regarding limitations of vessel size and draft has no relation to my point. So i will not go further on that.
AMVER Programme 5 - Tom Alex [2020, XLS]
AMVER Programme - Tom Alex [2018, XLS]
AMVER Programme 6 - Tom Alex [2022, XLS]
Duties of a third mate - Tom Alex [2018, XLS]
Alone Across the Pacific Ocean - Bellini A. [2013, EPUB]
Global Guide to Tropical Cyclone Forecasting - WMO [2017, PDF]
JRC GPS Navigator Instruction Manual JLR-7500-7800 - JRC [2009, PDF]
Furuno ECDIS Operation Slide Show / FEA-2807/2107/2107-BB - Furuno [2017, JPEG]
What to take to Sea - Tom Alex [2020, XLS]
RS CATALOG (ELECTRO,ELECTRONIC,AUTOMATION,TOOLS & OTHER EQUIPMENT) 2012 - RS [2012, PDF]
The time now is: Today 09:15
