frauslegi ®   03-Nov-2019 12:55
Air Conditioning Principles and Systems: An Energy Approach
Year: 2001
Author: Edward G. Pita P.E.
Genre: Technical book
Publisher: pearson
Edition: 4th
Pages count: 524
Description: Using a minimum of mathematics, this book explores the fundamental concepts of air conditioning and their application to systems—explaining all concepts in a clear, practical manner, and focusing on problems and examples typically encountered on the job. This book contains the most recent and industry-wide accepted information on load calculations, design data, equipment information, and use of the Internet. Specific chapter topics cover the scope and uses of air conditioning; physical principles; heating loads; furnaces and boilers; hydronic piping systems and terminal units; cooling load calculations; psychrometrics; fluid flow in piping and ducts; piping, valves, ducts, and insulation; fans and air distribution devices; centrifugal pumps, expansion tanks, and venting; air conditioning systems and equipment; refrigeration systems and equipment; automatic controls; energy utilization and conservation; instrumentation, testing, and balancing; and planning and designing the HVAC system; and solar heating and cooling systems. For consulting engineers, mechanical contractors, HVAC engineers, designers, project managers, and facilities managers.
Air Conditioning Principles and Systems- An Energy Approach
Arcan   03-Nov-2019 13:50
frauslegi, Check carefully before release creating to avoid unnecessary work.
Refrigeration and Air Conditioning - W.F. Stoecker, J.W. Jones [1983, PDF]
HVAC - Equations, Data, and Rules of Thumb, 2nd Edition - Arthur A. Bell JR., P.E. [2007, PDF]
HVAC Fundamentals - Samuel C. Sugarman [2007, PDF]
Air Conditioning Principles and Systems - Edward G. Pita - Edward G. Pita [2002, PDF]
Principles of Naval Engineering: Propulsion and Auxiliary Systems - Matthew A. Carr [2012, PDF]
2015 ASHRAE Handbook_HVAC Applications Heating, Ventilating, and Air-Conditioning Applications -…
Centrifugal Pumps - Johann Friedrich Gülich [2020, PDF]
Surface Production Operations Volume IV - Pumps and Compressors - Maurice Stewart [2019, PDF]
Know and Understand Centrifugal Pumps - L. Bachus, A. Custodio [2003, PDF]
The time now is: Today 17:31
