Reeds Vol 9: Steam Engineering Knowledge for Marine Engineers by Thomas D. Morton
Year: 2003 Language: english Author: THOMAS D MORTON Genre: Textbook Publisher: THOMAS REED PUBLICATIONS Edition: 3rd ISBN: 0-7136-6736-2 Format: PDF Quality: Scanned pages + text layer (OCR with mistakes) Pages count: 153 Description: The object of this book is to prepare students for the First and Second Class Certificates of Competency in the subject of Steam Engineering Knowledge. The text is intended to cover the ground work required for both examinations. The syllabus and principles involved are virtually the same for both examinations but questions set in the First Class require a more detailed answer. The book is not to be considered as a close detail reference work but rather as a specific examination guide, in particular almost all the sketches are intended as direct applications to the examination requirements. If further knowledge from an interest aspect is required the student is advised to consult a specialist text book, e-g., turbines, boilers, control theory, etc., as the range of modern marine practice has superseded the times whereby all the subject can be accurately presented in one volume. The best method of study is to read carefully through each chapter, practising sketchwork, and when the principles have been mastered to attempt the few examples at the end of the chapter. Finally, the miscellaneous questions at the end of the book should be worked through. The best preparation for any examination is the work on examples, this is difficult in the subject of Engineering Knowledge as no model answer is available, nor indeed any one text book to cover all the possible questions. As a guide it is suggested that the student finds his information first and then attempts each question in the book in turn, basing his answer on a good descriptive sketch and writing occupying about 1 f sides of foolscap in f hour. All the miscellaneous specimen questions given at the end of the book are from D.O.T. examinations together with the tea examples at the end of chapter one.
Genre: Textbook
Edition: 3rd
ISBN: 0-7136-6736-2
Pages count: 153
foolscap in f hour.
Notice from: zxc
Better quality
https://seatracker.me/viewtopic.php?t=63545
Reed's Vol 09 steam engineering knowledge for Marine Engineers.pdf
Download [15 KB]
Share
