skipper3362 ®   21-Jul-2019 21:42
Rhinoceros SR10 plus orca nautical plugin
Year: 2019
Version: 6.10.18258.23351
Developer: Jonathan Quinn Barnett Ltd
64-bit OS compatibility: yes
System Requirements: Windows 10, 8.1, 8, or 7 recommended, Windows Vista Windows XP (32-bit only) Service Pack 3
Note: Both 32and 64-bit versions are installed on 64-bit Windows systems.
Not supported:
Windows NT, 95, 98, ME, or 2000, Windows XP 64-bit
Crack: Included
Description: In Rhino 6 for Windows, we’ve fully embraced Grasshopper – the wildly popular visual programming language – by “baking it in.” Grasshopper is no longer beta; it’s a stable development environment. We’ve also rewritten some features and renovated workflows that needed fundamental overhauls to make them truly productive. These are the highlights. You can also download Enscape3D 2.3.2.703 for Revit SketchUp Rhino ArchiCAD.
The long beta period is over: Grasshopper, the world’s most beautiful programming language, is now a full-fledged part of Rhino. Used in some of the most ambitious design projects of the past decade, Grasshopper, like Rhino, has become a robust development platform. Grasshopper provides the solid foundation for many incredible third-party components ranging from environmental analysis to robotic control. You also may like to download Autodesk Inventor Pro 2019.1.2.
Features of Rhinoceros SR10 6.10.18258.23351 Free Download
Below are some amazing features you can experience after installation of Rhinoceros SR10 6.10.18258.23351 Free Download please keep in mind features may vary and totally depends if your system support them.
Extreme precision: Design, prototype, engineer, analyze, document, and manufacture anything of any size no matter how small or how large.
Unrestricted editing: Revise freely without concern about how you got there or where you want to go next.
2-D drafting, annotation, and illustration: In addition, flatten 3-D surfaces into 2-D patterns and drive laser, plasma, and water jet cutters.
Large project organization: Work with both large models and large teams.
Compatibility: Exchange files with your other design, drafting, CAM, engineering, analysis, rendering, animation, and illustration software.
File read and repair: Fix extremely challenging IGES and mesh files.
Direct connection: Support for wide variety of 3-D digitizing arms, 3-D scanners, and 3-D printers.
Customization: Easy-to-use tools let both you and software developers make Rhino fit your special needs.
Short learning curve: Focus on design and visualization without being distracted by the software.
Speed: Even on an ordinary laptop computer Rhino is fast. No special hardware is required.
Affordability: Ordinary hardware. Short learning curve. Priced like other Windows software. No maintenance fees. Worldwide support is included
Orca3D streamlines your design work with a suite of powerful applications that run within the Rhino 3D environment. Conceptualize, model, and analyze, all without transferring files or learning a new program. Create and fair hull, deck, and superstructure surfaces, analyze hydrostatics and stability, predict speed vs. horsepower, and track the weight, center of gravity, and cost of your design, all within a single environment. By itself, Rhino is an extremely powerful design tool; when you add Orca3D’s marine-specific tools, it becomes the most versatile and cost-effective marine design program available. Hydrostatics & Stability
Compute intact hydrostatics at the push of a button, analyze the intact stability of your design, and float your design to a specified displacement and center of gravity. Track downflooding points as the vessel heels.
Hull Design & Fairing
Start your design by entering parameters into a Hull Assistant, watching the shape and hydrostatic properties change in real-time. Fair the hull shape, using tools such as real-time display of sections (stations, buttocks, waterlines), forefoot control, and editing planes.
Speed/Power Analysis
Predict the resistance and speed of your design, using a Savitsky analysis for planing hulls or a Holtrop analysis for displacement vessels.
Weight & Cost Tracking
Assign weight and cost properties to the objects in your model. Total weight, center of gravity, and cost update as you edit your model.
rhino en orca 3d
leisure01   15-Feb-2020 15:40
Hi, could you provide instructions on what folder to extract files to and how to use patch? At the moment the program requests a license. Thanks in advance.
deepaikpooranachandran   08-Jun-2020 12:00
skipper3362, The orca version dose not work with rhino 5 also it throws a error saying module cannot be loaded can you please guide.
thanks in advance
Orca3D v.2.0.22 for Rhino v 7 Orca3D.x64-2.0-20210802 - Orca3D [2021]
Skymate Pro 2012 (beta 3F adjusted) [2012]
Rhino ship hull tutorial - Mark Pavkov [2007, PDF]
Excel 2019 Power Programming with VBA - Michael Alexander, Dick Kusleika, John Walkenbach [2019, PDF...
Chaos V-Ray v.6.00.03 - chaos [2023]
VisSim 6.0 / 7.0 + Addons [2013]
GPS-Dongle GD-75 v.1.0.5.18 - Prolific Technology Inc. [2008]
A tutorial on frequency adaptive communication systems in the HF bands - ITU [2022, PDF]
Warship No.02 - Robert Gardiner (Editor) [1977, PDF]
The time now is: Today 00:12
