maqmoura ®   17-Mar-2019 16:41
HVAC Troubleshooting Manual
Year: 1999
Author: J. Fletcher
Genre: Technical book
Publisher: BSRIA
Pages count: 110
Description: This document contains a detailed list of troubleshooting procedures for HVAC systems and plant and has been compiled from a number of different sources. The guid is aimed at maintenance personnel attempting to solve problems with specific items of plant.
Each item of plant has a series of "Symotims" thich describe different problems. 'Possible causes ' are given for each symptom together with appropriate 'Actions' to follow.
TO USE THIS GUIDE:
Refer to the relevant item of plant
Select the symptom that most closely matches the problem experienced
Follow the checking procedures outlined.
J. Fletcher - HVAC Troubleshooting Manual-BSRIA (1999).pdf
Download [7 KB]
Arcan   17-Mar-2019 17:12
maqmoura, It would be better if you do not use "content" pages in the screenshots. Try to make at least three screenshots from different parts of book that users could see the quality of scanned pages.
maqmoura ®   17-Mar-2019 17:32
Arcan, thank's for the advice. It's my first time posting some content.
The next post will be better.
Arcan   17-Mar-2019 17:37
maqmoura, well, next will be next. But I think you need a little bit edit this one release. How to edit your releases - read here
Arcan   17-Mar-2019 18:15
maqmoura, and after editing - do not forget to download back torrent file from site and add exactly downloaded file to your torrent client.
For now - "Registered: 1 hour 29 minutes | Completed: 0 times
Seeder not seen: Never"
It mean that nobody can download your file.
maqmoura ®   17-Mar-2019 18:34
Arcan, Done as requested. Removed 'Content' from 'screenshots' and inserted 2 new pictures to this last folder.
Downloaded torrent link and started in Bitcomet. I believe that now its gonna work.
Tanks a lot.
Arcan   17-Mar-2019 18:46
maqmoura, well, you completed with pictures but "Seeder not seen: Never" remained. something wrong with added torrent file. Do it correctly.
Centrifugal Pump User’s Guidebook, Problems and Solutions - Sam Yedidiah [1996, PDF]
Outbreak Management Plan: Covid-19 - Intertanko [2022, PDF]
Maintenance Guide CheckList (Lloyd’s Reg. cargo vessels) - Lloyd’s Register [2008, PDF]
Marine diesel engines: Maintenance, Troubleshooting, and Repair - Nigel Calder [2007, PDF]
Taiko 3 Screw, Centrifugal, Inside Bearing Gear, Piston & One Screw Pumps - Instruction Books -…
Detainable Deficiencies Guidance and PSC Check List - DBS [2021, PDF]
Practical Centrifugal Pumps - Paresh Girdhar, Octo Moniz [2005, DjVu]
Operation of Machinery in Ships: Steam Turbine, Boilers and Auxiliary Plant - A. NORRIS, C.Eng.,…
Cooling-water-and-additives-for-WinGD-engines_v3 - WinGD [2022, PDF]
The time now is: Today 21:57
