khany ®   04-Feb-2019 00:15
ECDIS Passage Planning and Watchkeeping
Year: 2018
Author: Witherby Publishing Group
Publisher: Witherby Publishing Group
Edition: 4
ISBN: 978-1-85609-779-6
Quality: OCR without errors
Pages count: 226
Description: ECDIS can contribute significantly to navigational safety and efficiency, however, this depends as much on the capability of the ECDIS operator. This publication shows how to produce a safe passage plan and safely use ECDIS when conducting a navigational watch.
This edition has been updated to reflect the latest IHO S52 Presentation Library 4.0 which came in to effect in Sep 2017 with advice on the significant operational impact of PL 4.0.
2018, sees the final tranche of vessels that are required to be fitted with ECDIS and completes a 6 year implementation period to move the worlds merchant fleet to ECDIS. This update fully recognises that ECDIS is the primary source of navigation onboard and brings together experience from ship's officers' and Masters in how ECDIS is most effectively used onboard.
Additional info: Also attached the Supplement with checklists
khany ®   04-Feb-2019 12:02
pash.push, sorry, I had problems with the connection but now its ok.
Passage Planning Guidelines - Witherby Publishing Group [2018, PDF]
Safe Nav Watch - Witherby Publishing Group [2019, PDF]
Teamwork on the Nav Bridge - Witherby Publishing Group [2019, PDF]
Passage Planning Guide: English Channel, Dover Strait and Southern North Sea - Witherby [2021, PDF]
Recommendations on Usage of ECDIS and Preventing Incidents - OCIMF [2020, PDF]
Bridge Procedures Guide - International Chamber of Shipping [2022, PDF]
Passage Planning Guide - English Channel, Dover Strait and Southern North Sea (2024-25 Edition) -…
Guidelines for The Training and Experience of Key DP Personnel - IMCA [2016, PDF]
ECDIS Passage Planning And Watchkeeping - Witherbys [2019, PDF]
ECDIS Passage Planning and Watchkeeping - Witherbys [2021, JPEG]
  • Topic closed
The time now is: Today 14:14
